using a RTC in SF basic
MrDEB
I have a DS-1302 RTC module but how to use it?
I recall Jon Chandler made a vu meter clock but what he used for timing?
Am planning on a clock that has no hands, just LEDs but precision would be nice.
I was trying to use 74hc595's but the math is not correct
60(seconds) X 8 (# of outputs) = 56 so we have 4 unused outputs
12(hours) / 8 (outputs) = 1.5
was contemplating counting DATA pulses so every DATA pulses (one every minute) would advance the shift register 1 bit.
I am using 10 PCB segments ... each Segment has 12 LEDs. 6 for minutes and 6 for hours...
MrDEB,
It is abundantly clear that despite hundreds of messages about using the shift registers you are still clueless about what they do.
You claim to have one shift register working with 8 LEDs. I challenge you to do the following exercise to help you understand. Each step here is only 2 lines of code. Post your code if you can make this simple exercise work. If you can't do this simple exercise, give up on using shift registers entirely.
Exercise: Light up the LEDs in the pattern shown, wait 5 seconds and move on to the next.
am about ready to give up on this. Tried several different codes but have yet to figure out the correct method to obtain desired pattern.
Am still attempting to get correct pattern
What is so difficult to understand?
To get
You shift out
 % 1 0 1 0 0 1 1 0
And toggle the latch pin.
been contemplating this idea but?
Now that I have a working shift register.
any thoughts on this beginning schematic?
  • Schematic_clk-595_2025-06-17.pdf
Still trying to use the shift registers as a ring counter apparently. Looks like the entire concept has been, ah, misplaced.
Lots of parts to illuminate TWO LEDs at a time.
