using a RTC in SF basic
MrDEB
I have a DS-1302 RTC module but how to use it?
I recall Jon Chandler made a vu meter clock but what he used for timing?
Am planning on a clock that has no hands, just LEDs but precision would be nice.
Here some code for mr deb to play with un tested just change to your chip and send out 1 and 0
' File:      main.bas
' Author:    burt and AI
' Created:   July 31, 2025
' Target:    PIC18F252
' Compiler:  Swordfish BASIC
' Description:
' This program demonstrates sending a byte of data to a 74HC595 shift
' register using a PIC18F252 running on a 20MHz external crystal.
' This version uses a custom subroutine to shift the data out.
' Hardware Connections:
' PIC18F252        ->   74HC595
' RC0 (Pin 16)     ->   DS (Serial Data In, Pin 14)
' RC1 (Pin 17)     ->   SHCP (Shift Register Clock, Pin 11)
' RC2 (Pin 18)     ->   STCP (Storage Register Clock / Latch, Pin 12)
' The 74HC595's OE (Output Enable, Pin 13) should be tied to GND to enable
' the outputs, and MR (Master Reset, Pin 10) should be tied to VCC to
' prevent resetting the register.
' --- Device and Clock Configuration ---
Device = 18F252
Clock = 20
Include "Utils.bas"
' --- Configuration Fuses ---
Config
    OSC = HS,           ' High-speed crystal oscillator
    WDT = Off,          ' Watchdog Timer disabled
    LVP = Off,          ' Low-Voltage Programming disabled
    BOR = Off,          ' Brown-out Reset disabled
    PWRT = Off          ' Power-up Timer disabled
' --- Pin Aliases for 74HC595 ---
Dim DataPin As PORTC.0      ' Alias for the Data pin (DS)
Dim ShiftPin As PORTC.1     ' Alias for the Shift Clock pin (SHCP)
Dim LatchPin As PORTC.2     ' Alias for the Latch/Storage pin (STCP)
' --- Variable Declaration ---
Dim DataToSend As Byte
' --- Custom Subroutine to send a byte ---
' This subroutine manually sends a byte of data, bit by bit.
Sub ShiftOutByte(pData As Byte)
    Dim i As Byte
    ' Loop 8 times for 8 bits
    For i = 0 To 7
        ' Check the most significant bit (MSB)
        If (pData And %10000000) > 0 Then
            High(DataPin)
        Else
            Low(DataPin)
        End If
        ' Pulse the shift clock to send the bit
        High(ShiftPin)
        Low(ShiftPin)
        ' Shift the data to the left to get the next bit
        pData = pData << 1
    Next
End Sub
' --- Main Program ---
Sub Main()
    ' Initialize the data to send. % is used for binary numbers in Swordfish
    DataToSend = %10101010
   SetAllDigital()
    ' Main program loop
    While True
        ' Send the byte of data to the 74HC595 using our custom subroutine
        ShiftOutByte(DataToSend)
        ' Now, pulse the latch pin to move the data from the shift
        ' register to the output pins.
        High(LatchPin)
        DelayUS(10) ' A small delay to ensure the latch registers the pulse
        Low(LatchPin)
        ' Wait for half a second
        DelayMS(500)
        ' Invert the data for a blinking effect on the next loop
        DataToSend = Not DataToSend
    Wend
End Sub
