Pic18f25q10 osccon1 settings swordfish basic
Toggle a pin without delay looked at the instruction cycle in the ASM then measured it with my logic tool to see if they matched a 64 MHz clock they don’t the period was 1.5 MHz
Yes so going by that the period for asm toggle should be 4 mhz so the clock is not running at 64 MHz it running at half that
There is a setting for high speed, internal clock to run a 64 Ian said that fixed it on some xc8 code
In pill I’ve not tried it out
I reckon this could be Ideal candidate for the Pi Pico as that has programmable core pin outputs.
Pico's can be programmed in the arduino environment and are around £5
And if you like basic.. Well the MM basic is bluddy good.. Check Geoff's page https://geoffg.net/picomite.html
LOL.. He has even done the hardware support for the WS2812's NOTE** sorry bitbanged.
I read yesterday that the reason ardunio works is a 16 MHz avr is basically the same as a 64 MHz pic
Long story short I got the bit bang code to work after I got the pin runing at 64 MHz
