EternityForest
Someones gotta have made this before, but anyways:
Most common random number generators in use use either multiplication(BBS,LCG,etc)
or array acesses(ARC4),or variables bigger than a byte(XORSHIFT).
All of these things are not so good on an 8 bit chip.
so, I designed this algorithm, which is easy to understand, produces decent numbers(passes most of the diehard tests,except the sparse occupancy and DNA tests)
and will only use 4 bytes of ram and very little code space.
Obligatory dont-use-this-for-crypto-disclaimer here, It will not do good at that.
If you have the ram, by all means, use RC4. Its a great fast algorithm that is easy to use. But if you need something small i think this might be useful.
Here is a C library with comments for ya!
Most of the code is just comments, the main function is 5 lines.
What do you guys think?
//X ABC Algorithm Random Number Generator for 8-Bit Devices:
//This is a small PRNG, experimentally verified to have at least a 50 million byte period
//by generating 50 million bytes and observing that there were no overapping sequences and repeats.
//This generator passes serial correlation, entropy , Monte Carlo Pi value, arithmetic mean,
//And many other statistical tests. This generator may have a period of up to 2^32, but this has
//not been verified.
// By XORing 3 bytes into the a,b, and c registers, you can add in entropy from
//an external source easily.
//This generator is free to use, but is not suitable for cryptography due to its short period(by //cryptographic standards) and simple construction. No attempt was made to make this generator
// suitable for cryptographic use.
//Due to the use of a constant counter, the generator should be resistant to latching up.
//A significant performance gain is had in that the x variable is nly ever incremented.
//Only 4 bytes of ram are needed for the internal state, and generating a byte requires 3 XORs , //2 ADDs, one bit shift right , and one increment. Difficult or slow operations like multiply, etc
//were avoided for maximum speed on ultra low power devices.
init_rng(s1,s2,s3) //Can also be used to seed the rng with more entropy during use.
//XOR new entropy into key state
a ^=s1;
b ^=s2;
c ^=s3;
x++;
a = (a^c^x);
b = (b+a);
c = (c+(b>>1)^a);
unsigned char randomize()
x++; //x is incremented every round and is not affected by any other variable
a = (a^c^x); //note the mix of addition and XOR
b = (b+a); //And the use of very few instructions
c = (c+(b>>1)^a); //the right shift is to ensure that high-order bits from b can affect
return(c) //low order bits of other variables
