The VHF radio installed in my Italian aircraft is a military model. The mic audio-in is labeled "carbon mic". Don't know much more about the radio except that it says Marconi model number ART 151. I think it is in fact a Collins unit made under license because it looks like a Collins. Anyway, we've been using two noise canceling headsets with carbon mics that run though an audio panel/intercom made by some unknown (to me) Italian company called Gemelli. It's noisy in the cockpit because there is no VOX or squelch.
I just brought a new NAT AA12-200 audio panel/intercom for use with general aviation headsets and made a patch cable to connect it to the aircraft in place of the existing unit. Using a new set of general aviation noise canceling headsets with electret (Lightspeed 3G's) I find the intercom works great (of course - that's only a function of the NAT unit) plus you can hear the radio. However, I cannot transmit or hear a side tone (you can't hear your transmission in the headset).
To make matters more complicated, there are two resistors and a capacitor in the mic audio line from the audio panel to the radio. One resistor and the capacitor are in series and the other resistor connects the mic line to ground. I see then on the aircraft wiring schematic but I have no idea where to find these components in the aircraft! They are buried. The mic line ohms out to 92 ohms to ground. I could run a new line from the radio to the intercom to bypass these components if necessary. My guess is the capacitor is blocking dc voltage getting to the radio. I also think that this has something to do with the need for a DC bias voltage on the Lightspeed electret mic. I tried apply a voltage of around 4volts but still nothing. There is still obviously an interface issue.
Anyone know how to get this to work?
FYI - the aircraft operates on 28Volts DC.
