Trying to use a L9110s motor driver chip
JT2
I have this L9110S DC Motor Drive Module (https://www.amazon.com/dp/B0D17PJ2MS?ref=ppx_yo2ov_dt_b_fed_asin_title)
that has 2 L9110s motor drive chips on it.
I am trying to drive a little top motor and control this from an Arduino nano. I have the arduino drive 2 outputs, one high and one low, with these connected to IA1, IB1 and the motor connected to OA1,OB1. Nothing happens, however if I connect a ground to either IA1 or IB1 the motor will turn on. Very odd...
Anyone have experience using this device?
There is also another thread on this device here:
What voltages are you using?
Do you have the Arduino ground connected to the driver module ground?
With the outputs permanently set high & low, what voltage do you get on the module inputs?
The L9110S is decent for basic motor control, but if you're planning to expand into wireless or IoT-based motor control, integrating a module like the EM3586-RTR could be a great step. It combines Zigbee connectivity with low power consumption, making it ideal for remotely controlled or sensor-integrated motor systems.
Hi, any update?
