triac required
myson
Does anyone know where I can get the following triac, they are for a powakaddy control board,
IRF Z 48N and TIC 126M,
Anything that will do the job will be fine,
Thanhs
IRF Z 48N
IRFZ48N
Discontinued
N-channel enhancement mode standard level field-effect power transistor in a plastic envelope
using ?trench? technology.
The device features very low on-state resistance and has integral zener diodes giving
ESD protection up to 2kV.
It is intended for use in switched mode power supplies and general purpose switching applications.
Datasheet
https://www.electro-tech-online.com/custompdfs/2006/08/IRFZ48N_1.pdf
Application Notes
https://www.electro-tech-online.com/custompdfs/2006/08/AN10273_1.pdf
Product Page
Cross referances for IRFZ48N
IRFZ48NPBF IR
STB60NF06T4 STMicroelectronics
STP60NE06-16 STMicroelectronics
FQP65N06 Fairchild
NDB7060 Fairchild
HUF75333S3 Fairchild
Mouser has all of the Above The original is $1.75 each
http://www.mouser.com/search/ProductDetail.aspx?R=IRFZ48Nvirtualkey56050000
All Matches at Mouser
http://www.mouser.com/search/Refine...ll&Mkw=irfz48N&N=1323038&Ntk=Mouser_Wildcards
Digikey has them for 92 cents each
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=1159&Row=433219&Site=US
TIC126M
SCR 12 Amp 600 Volt
Datasheet
https://www.electro-tech-online.com/custompdfs/2006/08/tic126d.pdf
TYN612RG
Cross Reference
Match for:TIC126M
TYN612RG STMicroelectronics
Mouser has them for 94 cents each
http://www.mouser.com/search/refine.aspx?Ntt=TIC126M
Digikey is $1.50 each
Datasheet
http://www.st.com/stonline/books/pdf/docs/7475.pdf
