Trail camera
KevinW
Anyone happen to know what these metal canister looking things are, marked 12000?
I discovered a corroded one in my camera.
Inside the can is a crystal that resonates. Just like a tuning fork. Most likely yours is12mhz. (not certain)
Corrosion is probably OK.
Dose the camera work?
Thanks Ron.
The camera stopped working.
There is a flashing indicator light when the camera is switched on and it's getting 6vdc from both sources, (battery and adapter) but that's about it.
I have 3vdc leaving the switch so I assume that's ok.
I don't see anything obvious, I sprayed the board with contact cleaner but nothing changed.
