Shelton said:Hi all
I am very new to the field of electronics and would like to take it up as a hobby. Can someone tell me what the total resistance is in this circuit?
I calculated it by using all resistors in parrellel. Is this correct?
here is the schema:
Souper man said:well, you could measure the resistance through the battery clip...
Nigel, I used this method to measure the resistance in my spagetti 2.0/It pivots robot, to get 15k. It even has a comparator, and some transistors and some other stuff, so i guess you could!
A better question would be; how much current will this circuit draw?Can someone tell me what the total resistance is in this circuit?
ThermalRunaway said:In order for a short to appear across the supply terminals of that circuit, you would need to have s/c resistors as well as transistors. Not to mention the diodes. I've never ever experienced an s/c resistor and infact I don't think it's possible to acheive with modern resistors.
Brian
Shelton said:Hi all
here is the schema:
