teflon don
hey guys
im planning on building a circuit that could regulate the time that a solinoid valve remains open
i want that each time i press micro switch that the valve remains open for regulated amount of time (preferably that i can dial in with a potentio meter
its important that each time the valve remains open for the exact amount of time regardless of how long i press the switch (for example if i press the switch for one second the valve remains open for 3 seconds if i press the siwth 10 seconds the valve still remains open for just 3 second)
but the systhem has to reset when i release and repush the switch (i.e. tapping the swich would cause the valve to be open continiously)
the valve works on 12 volt dc and uses about 60 amps (peak) and i want to keep the current trough the switch low to avoid arcing and contact erosion (a mosfet will solve that problem)
the circuit has to be as compact as possible and i can't programe pic
so can it be done
so can it be done
