Tda2005
BigE4u
Alittle help if you please... i can build the circuit with the chip mentioned, but what chip(preamp) would compliment this circuit best to make everything work properly. thanks
Ps- I plan on hooking this up to portable MP3/CD players and be used in a vehicle using the +12v power source.
crutschow
Most Helpful Member
I would think you could just connect the headphone output of the player to the input of the TDA2005.
Hero999
Banned
The schematic is on the datasheet which I found using Google.
BigE4u
Been there, done that.... im still not quite sure what else i need as far as a preamp thats needed, if any.
audioguru
Most Helpful Member
Most preamps have tone controls, a balance control and a front-rear fader.
BigE4u
I wasnt exactly looking to have tone/balance controls... i just thought since this is a full blow amplifier, it would need a preamp. The specs shown in the PDF look confusing to me when it talks about the "input" sensitivity. I wasnt sure if i needed a preamp or i could just plug my portable MP3/CD player directly into the amplifier. So basically what im asking is, does this amplifier need a preamp or will a MP3/CD player provide enough "signal" to fully use the amp. thanks
audioguru
Most Helpful Member
The TDA2005 circuit in the datasheet has plenty of gain. All you need is a volume control but no preamp is needed.
rdmwc
audioguru is correct, no preamp is needed. i used that chip in an amp i made last month to hook my mp3 player to a stereo i built for my motorcycle. works great! just use the volume control on your mp3 player or you could put a pot. before the amplifier.
BigE4u
I plan on just using the volume control on the portable MP3/CD players.
