I need some help designing a power supply for an amplifier. I have gathered that the bulk of a subwoofer amplifier is a power supply which steps up the 12V(which is standard in most cars) to 20-60volts depending upon the amplifier. Correct me if i'm wrong, but i believe this is because you need a higher voltage to send more current through your speakers(which are usually 2ohm or 4ohm). So actually it is a simple calculation involving ohm's law.
I want a power supply that can continuously supply 60vdc@15amps. My theory is to invert the 12 volt battery current to square wave, which would be 6vac correct? Then i would have to send it through a step up transformer and the windings would be 1:10 correct? My questions are as follows: where can I find a toroidal transformer which could handle this much load and be very small, what is the most ideal frequency, would a pwm need to be a part of this? If you could answer all three questions it would be greatly appreciated. Thank you!
