I would like to say Hi to everyone and thanks for taking the time to read this.
Here it goes-
I'm planning a custom PC case, one which the power on and power off are two different switches. I want the same switch to do both, so I drew this little thing -->
When the PC is powered off, the switch is the Mobo's power switch. When the switch is triggered, PC turns on, PSU goes high, energizing the relay, making the switch my "keyboard" F2 key (which is the hotkey for system shutdown). When the system shuts down, PSU goes dead, reverting the switch back to being the Mobo power switch.
In my mind, this should work as expected but then again I am no electronics guru. I have read that relays can make current surges/spikes and what-nots when switched. Do I have to worry about that? Do I have to worry about the relay restarting the PC when it switches off? If so, what can I do to solve these problems or any other problem you guys can see with this?
This is my first time working with relays so I just wanna make sure this will work before I blow the mobo header or keyboard.
Thanks for any replies.
T.
Here it goes-
T.
