SATA to USB converter
asp1987
I plan to make a SATA to USB converter so that I can use the internal hard disk of my desktop as an external storage device for the laptop. I would like to know how to go about interconnecting the data pins of USB and SATA.
Can you please guide me on connecting the Data- and Data+ pins on the USB to A+, A- (Transmit pins) and B+, B- (Receive pins) on the SATA cable? Is there any need for ICs to act as a bridge between the two?
Also, I would be grateful if you could explain the meaning of + and - symbols for the same function. Differential signalling?
SATA pinout: https://pinouts.ru/HD/serialATA_pinout.shtml
USB pinout: https://pinouts.ru/Slots/USB_pinout.shtml
Thanks.
Dude just buy an external hard drive case and be done with it.
External Hard Drive Case
Yes, just buy a case - that will include the required electronics (not just a lead) for the conversion.
Thanks for the replies. And special thanks to Nigel. It has been a while since I visited this site and feels good to get a reply from you right away. :)
I did look out for online purchases, but the costs are high ($25 = 1100 INR). The hard disk I am trying to convert is old, ~320GB while I can get a 500GB external USB by spending only twice the above amount. Hence it makes more sense to make a converter (if possible) than spend such amount.
You need a chip to go between the USB and the SATA. I dont think i have the part numbers around anymore, but it's simpler and cheap to buy an 'adapter', not a whole case, but just the USB to SATA adapter. Make sure it says it works with a SATA hard drive.
Looks like it's a difficult DIY project. Sigh..
Btw, this chip does the trick- JM20337 https://www.electro-tech-online.com/custompdfs/2011/07/JM20337.pdf
Thanks for the reply, MrAl. :)
Look for an adapter on ebay from Hong Kong :-) You can probably find one for under 10 dollars.
yes the prices for the case are quite high but have you seen he material used for the external case? its aluminium and it just sheds off the heat hard drive. so you dont lose your performance. I have also made 1 TB seagate and the case also costed me 1100 INR. so just buy the case. its goeed and reliable. but still if you want to make your own, then go to a computer accessory dealer. these parts are now available in the computer shops cheaply
my case is a good quality case and is full thick metal aluminium. it has one power adaptor also. what kind of material is your case?
Same. Al case with a power adapter, driver CD, USB cable, and a star screw-driver :D . Screw driver was too much of an overkill. Value addition. :P
i dont have to use the driver CD. still if you have got a good one you're lucky. in which city have you got it? may be i could order it for my next drive..
Yup. Glad that I could be of some help. :)
I got it from a computer shop at my place- Trivandrum. I put up the link to the online shop in an older post as both products are one and the same.
And ditto here about the need for driver programs. By including the driver CD, its manufacturers targeted older OS's like Win 98 (I have Win 7), and Linux.
can you send me the driver for win 98? here in my office we still have the good old 98. and i want to connect the Hdd to it. you can post it in rar here or on my mail. roltex_rohit123@yahoo.com
Can you tell what kind of hard disk you have? As in SATA/ IDE etc? There are plenty of setup files in the CD (117MB). Have attached the list of setup files.
