parallel-to-serial problem
earckens
Active Member
A pcb for 24 inputs and 48 outputs (using serial-to-parallel and parallel to serial 8-bit registers) is working flawless with its controller program.
Now I also designed a 72 inputs (72IN) board using 9 8-bits paralle-to-serial-8-bit registers based on the pcb 24IN/48OUT concept.
I adjusted the program accordingly yet this does not work. To prove that my program is ok I modified that program to work on the 24IN/48OUT pcb, only reading the inputs: that works well.
I then tested my modified program on the 72IN pcb and again not working (not reading the 24 first inputs).
So to me that proves there is an issue with the hardware of the 72IN , and/or its combination with my 72IN program.
Attached are the schematics for the 24IN/48OUT pcb and the 72IN pcb. I am at my wits end (cannot see the forrest through the trees) about this so I decied to post my question on this forum.
Please have a thorough look at my schematics, and any pointers, hints, .. are welcome.
Erik
Below here is my code for the reading of 24 inputs ony:
(EDIT: which does work on the 24IN/48OUT pcb but not on the 72IN pcb)
C++:
#include <Auto485.h>
#include <CMRI.h>
#include <SPI.h>
#define CMRI_ADDR 0                       // select the CMRI node address
#define DE_PIN 2                          // Arduino pin 2 -> MAX485 DE and RE pins
#define NOP __asm__ __volatile__ ("nop\n\t") // https://forum.arduino.cc/t/very-short-delays/43445/5
#define input_groups 3                    // each group = 8 input bits; if 72 inputs then = 9
// pin 74HC165
const byte LATCH_165 = 9; // LATCH pin
Auto485 bus(DE_PIN);                      // RS485 bus transceiver
CMRI cmri(CMRI_ADDR, 24, 0, bus);       // sets up an SMINI with address 5, SMINI = 72 inputs, 0 outputs
uint8_t input_state[3];
void setup() {
  Serial.begin(9600);
  delay(100);
  Serial.println(__FILE__);
  Serial.println("DCCpp_CMRI_nopxor72-in_v5.ino");
  Serial.print("C/MRI address : ");
  Serial.println(CMRI_ADDR);
  delay(1000);
  bus.begin(57600, SERIAL_8N2);           // open the RS485 bus at 57600bps
  SPI.begin ();                           // serial data protocol used to control 74HC165
  pinMode(LATCH_165, OUTPUT);
  digitalWrite (LATCH_165, HIGH);
  // initialize last_input_state array with current input state
  digitalWrite(LATCH_165, LOW);              // pulse the parallel load latch
  delay(1); // wait while data loads
  digitalWrite(LATCH_165, HIGH);
  input_state[0] = ~(SPI.transfer(0));
  input_state[1] = ~(SPI.transfer(0));
  input_state[2] = ~(SPI.transfer(0));
void loop() {
  // 1: main processing node of cmri library
  cmri.process();
  // 2: update inputs
  digitalWrite (LATCH_165, LOW);          // pulse the parallel load latch
  NOP;                                    // use the macro instead of inline assembly
  NOP;
  byte new_input_state[3];
  new_input_state[0] = ~(SPI.transfer(0));
  new_input_state[1] = ~(SPI.transfer(0));
  new_input_state[2] = ~(SPI.transfer(0));
  if (memcmp(new_input_state, input_state, 3) != 0) {
    memcpy(input_state, new_input_state, 3);
    cmri.set_byte(0, new_input_state[0]);
    cmri.set_byte(1, new_input_state[1]);
    cmri.set_byte(2, new_input_state[2]);
  // 4: wait for next iteration
  delay(1);
danadak Dear, please do not post spam, AI-generated content or useless information. Thank you.
Its not spam, not AI, just another way of doing your design with less parts.
The SIPO I show I did. As part of self teaching Verilog was my motivation
in 2020.
But given your interpretation of post I will no longer comment on your posts.
I think thats best for both of us.
danadak , that is a good idea.
My OP addressed a very specific issue that does not need another design concept. The other posters in this thread have put me on the track to the solution which is great.
"unconnected Vcc" by what measure? physical solder gap, resistance test?
In my posts #17, 18 and 19 I showed how GND of the controller is not connected to PCB and supply GND.
Somehow in my Eagle symbol for this controller I had the GND pins as "nc", ie "not connected", while the symbol VCC pin is connected to "pwr".
This results in Eagle automatically connecting the VCC pin of the controller to VCC of the PCB... While the GND pin of the controller was stated as "nc", hence no ground connection to the controller.
