Samsung tv what the heck (screen problems)
stk2008
Hi all I hope some one has seen this issue before.
My dad has an LCD screen that has issues with the picture as you can see
the screen dont looked damaged I think but I wonder if its the control board.
any ideas please
EDIT
its been under the stairs for months hence the dust :p
Yeah, the vertical control board. My brother in law had a similar issue with a display of his, the replacement board cost more than the unit was worth and no cause for the failure of the board was ever found so even if he replaced it there's no saying that the true cause of the boards failure wouldn't happen again. What's left of it is now safely in my stack of parts to be bulk desoldered for reuse =)
darn oh well thanks for the reply IF I can get a cheap board I may try but other than that parts it is.
EDIT
Sorry what is the LVDS BOARD do and is this the part?.
Sorry to be a pain but I have taken it apart and as suspected nothing stands out I have checked for loose connections of the ribbon cables but they seemed ok.
what does the vertical control board look like in a le32a457 tv?
thanks
EDIT
I just checked fuse F1 on this board and its ok
UPDATE
I have just taken the LCD screen out and the layers of film that go between the screen and the lamp and there wet there is some kind of fluid in between it.
I hope its not the LCD liquid (the screen dont look cracked) or it may be water or cleaner hence this caused the problem.
If it is the LCD liquid is this dangerous as I have touched it?.
Sorry to keep going on I have tested it again and still the same.
Its funny because when I very first turn in on its fine then 10 seconds or so later it developes the problem you see in the pictures in my first post.
If I replace this **broken link removed** would this POSSIBLY fix it?.
thanks
