Hey guys,
Got an interesting one. A buddy of mine has a sport bike that he runs nitrous on. The problem is if you hit the engine limiter while spraying it does very bad things like blow up the motor and cost a ton of money and down time. So I was thinking of maybe building some sort of RPM activated switch to interupt the nitrous circuit right before the engine limiter is hit.
It's a 4 cylinder 4 stroke motor so it will have 2 tach pulses per crank shaft revolution. He says the limiter activates at 14500 rpm so we'll make the RPM activated switch happen at 14000rpm which is 28000 tach pulses per minute which is 466.66 pulses a second.
So is it possible to build such a circuit? Something that would be activated at 466hz or higher? I have no clue how to go about something like that. I assume some sort of frequency counter circuit?
Thanks for any pointers on a circuit to build such a thing, if possible.
Malcolm
Malcolm
