"In this project, requires to design a model of missile, which controlled by the PC.
At first, the target is designed such a way that it continuous sending signal with constant frequency.
The missile is designed such a away that it can capture the target signal only.
Once it has processed by the PC, the user press "enter" key to launch the missile.
So, whenever the target is going, the missile will keep on follow it till mission completed.
The software used in VB (Visual Basic)/ The VB should obtain the target signal, and then send the signal back to the missile after processing. VB also will trigger the missile."
Missile can be replaced by a guilded toy car or something else. I think the main objective in this project is the tracking signal system. Can i have some ideas on this project from you guys - experts.
Thanks.
Thanks.
