Resistors in series with rectifier
Diver300
Most Helpful Member
I've just fixed an amplifer/tuner. The transformer has a main and an auxiliary output. The auxiliary output has 1 ohm resistors on the AC side of the rectifier.
The resistors were 1/4W film ones, and had failed. There was no burning to indicate failure, and one had gone open circuit, and the other read around 200k ohms.
What are the resistors for? I had never seen resistors like that before. They seem to be rated at too low a power rating, so I replaced them with larger ones.
Nigel Goodwin
Super Moderator
Most Helpful Member
A mixture of surge limiters and fuses, so you shouldn't really replace them with larger ones, and the originals might even be special fusible resistors.
unclejed613
Most Helpful Member
if the originals were flameproof types (which from experience i would expect them to be) they should be replaced with flameproof types. it's very likely something else is wrong at or after the rectifier if they're blown. a shorted regulator or rectifier are likely.
colin55
The resistors have gradually "burnt out."
They are "fuses" or "safety resistors" or "fusible resistors."
Replace them with the same type.
EE World Online Articles
Loading
