request circuit for rpr-220 photoeye
yeild
The circuits I have tried have only yeilded a output voltage change from .2V to .5V Any help would be appreciated. I am attaching the circuit that I have tried to use and also the data sheet for the sensor that I am using.
hi yeild,
Looked at the spec and cct diagram, from what I can tell the change will
be small.
How are testing it to get the voltage change you posted ?
All I could find is a 'test cct'. Is this the way you are testing?
EricG
Hi Eric,
The test circuit pdf is how I am currently testing it. I will be hooking the Vout signal on the schematic to a input on a 8051 microcontroller.
I don't see anything wrong with the test schematic. Your drive LED bias current is fine. The collector load is fairly high, so you shouldn't have a gain problem. It should switch between 0 and 5 volts. You may have these problems:
- incorrect wiring of components
- too much light entering the sensor at all times. Try blocking all light from the sensor to see if the transistor will then switch off.
