I'm building a data logger using a Nano and an SD holder(5V converters). I need to log two 5V analog voltages and a few(5) 12V digital voltages. For the 12V inputs I'm considering just a series resistor of 10k (or maybe 22k) so the ATMEGA input will see 5.7V and ~0.6mA which exceeds the datasheet value of Vcc+0.5V.
I'm assuming that when the chip is powered down that the power LED will hold Vcc at ~2V (assuming back powered) and keep the processor in reset. I'm more worried about when it's powered as the max rating is definitely exceeded.
However, when powered down is Vcc classed as 0V? So it still exceeds Vcc+0.5V no matter what I do.
Does anyone know the forward voltage of the protection diodes (@100uA)?
Has anyone done this and what were the results.
Thanks,
Edit, anyone know what the Vbor is for this chip? Can't find it in the datasheet.
Thanks,
