Relay
shermaine
I have got some doubts.
What's the different between the coil rating and contact rating?
Are they the same?
PLease advise.
Are they the same?
PLease advise.
No they are totally different - as the names suggest, one is the rating for the coil (that actually activates the relay, this is usually given as a voltage and a resistance - for example 12V 240 ohms). The other is the rating of the contacts, the actual switch which opens and closes as the relay is turned on and off - the ratings for this will give voltage and current, and usually for both Ac and DC - DC will have a far lower current rating.
A relay is simply a coil (electromagnet) that moves a pair of contacts (switch).
