Receiving data from comport !!
You are trying to capture data while you are displaying to the text box.
Capture the data in an array, say 15 bytes of raw data, dont try to display while you are capturing.
The Sync byte of you data file is attached, the oximeter says its waiting too long.
I am logging off for the day, I will modify and post a new VB program for you tomorrow.
This simple program works with a test string equivalent to the output of the Oximeter.
I have decoded/masked some of the data, you should do the remainder.:)
Option Explicit
Dim X, Z As Byte
Dim BitStr, BitStr2 As Variant
Dim arry(15)
Private Sub Form_Load()
MSComm1.CommPort = "2"
MSComm1.Settings = "4800,O,8,1"
MSComm1.InputLen = 0
MSComm1.PortOpen = True
End Sub
Private Sub lblBar_Click()
End Sub
Private Sub lblSignal_Click()
End Sub
Private Static Sub MSComm1_OnComm()
Dim Data
Dim strchr As String
Dim strlen, valchr, X, Z, Y As Byte
On Error GoTo fail1
   Select Case MSComm1.CommEvent
        Case comEvReceive
            Dim Buffer As Variant
            Buffer = MSComm1.Input
            Data = (StrConv(Buffer, vbUnicode))
            strlen = Len(Data)
            ''Text1.SelText = strlen & vbCrLf
            For X = 1 To strlen
            strchr = Mid$(Data, X, 1)
            valchr = Asc(strchr)
            Next X
            If valchr > 127 Then
            Z = 0
            arry(Z) = valchr
            '''Text1.SelText = Right$("00" + Hex$(arry(0)), 2) & ","
            Else
            Z = Z + 1
                If Z > 14 Then Z = 0
            arry(Z) = valchr
            '''Text1.SelText = Right$("00" + Hex$(arry(Z)), 2) & ","
            End If
    End Select
If Z > 3 Then
MSComm1.PortOpen = False
Decode
End If
Exit Sub
fail1:
Z = 0
valchr = 0
End Sub
Private Sub Decode()
Dim S, X As Byte
        Text1.Text = ""
        For X = 0 To 4
        Text1.SelText = Right$("00" + Hex$(arry(X)), 2) & ","
        Label1(X).Caption = Right$("00" + Hex$(arry(X)), 2) & " "
        Next X
        Label3(0).Caption = arry(0) And &H7
        Label3(1).Caption = arry(1) And &H7F
        Label3(2).Caption = arry(2) And &H7
        Label3(3).Caption = arry(3) And &H7F
        Label3(4).Caption = arry(4) And &H7F
    'check for bit 6 in arry(2)
    If arry(2) And &H40 = 1 Then
    Label3(3).Caption = (arry(3) And &H7F) Or &H80
    End If
        Z = 0
End Sub
Static Function Bin2BinStr(PrtVal As Integer)
'converts a 8 bit string value to 8 bits
Dim binmask, p As Integer
BitStr = String(8, "0")
 If PrtVal > 127 Then
    Mid$(BitStr, 1, 1) = "1"
    Else
    Mid$(BitStr, 1, 1) = "0"
 End If
    If PrtVal < 0 Then
    End If
 binmask = &H40
 For p = 2 To 8
    If PrtVal And binmask Then
    Mid$(BitStr, p, 1) = "1"
    End If
    binmask = binmask \ 2
 Next p
BitStr2 = BitStr
End Function
[I]**broken link removed**[/I]
  • oximV1.txt
hi salem,
Ref your PM, I would prefer to work on the problem using the Forums, other members may find our posts useful.
I will continue to work on this with you until its working or we decide to shelve the project. OK.:)
I have used the original protocol and formatting pdf to create a test string of 5 bytes via a UART transmission program from another PC into that program I posted and it does what I expect.
Tell and show me the results you are getting with the program I posted yesterday
Ok,
i got freezing all the time when i open the comport ( but the input data shows in the TextBox ) and can't press any thing at all in the app !! till i unplug the device from the PC
then a message will appear ( normal msg about the device is not open ... )
at that time i only see the decoded of the bytes be in lables to show the data as u did
till now i am not sure about the data i need which are ( Pulse , Heart Rate ,, etc )
Thank u very much Eric
B8,3F,3F,3F,3F,
theses what i got in the text box
mm not appear in the labels till i unplug the device from the pc then show up
when i put my finger on the device to check the result will be like the following :
C0,3F,3F,3F,3F,
CA,3F,3F,3F,3F,
93,3F,3F,3F,3F,
95,3F,3F,3F,3F,
BE,3F,3F,3F,3F,
BD,3F,3F,3F,3F,
C9,3F,3F,3F,3F,
Notice that only the 1st byte changes
Your results suggest that the signal strength is erratic, the sync byte/bit 7 seems to be detected correctly.
Do you have any more technical info on the oximeter.??
I cannot explain the string of 3F's.???
C0,3F,3F,3F,3F,
CA,3F,3F,3F,3F,
93,3F,3F,3F,3F,
95,3F,3F,3F,3F,
BE,3F,3F,3F,3F,
BD,3F,3F,3F,3F,
C9,3F,3F,3F,3F,
C0 1=sync, 1=beep, 0=drop SpO2,=search, 0000=signal for Pulsate.
CA 1=sync, 1=beep, ....................................1101= 10
93 ................................................................0011=3
95 ................................................................0101=5
BE ...............................................................1110=14
BD ...............................................................1101=13
C9 ................................................................1001=9
no i just have the PDF only
btw the USB device shows in device manager as a virtual comport but it works fine as a real comport when talk to it using VB or its exe app ....
Thanks Eric
Thanks Eric
If I post a binary test file, do you have a another PC that you could use to transmit the test string, via the RS232 [USB] cable link to the PC with my VB5 ONCOMMs test program.???
i do have another PC with RS232 for both
but the cable should i use not exist between them i think i have to have RS232 cable ( Female with both sides )
but what can we get if we test that program ? is it useful for our issue with Oximeter !!!
Thanks Eric ,,,
Thanks Eric ,,,
I think by checking with a known data pattern we will be able to confirm that the VB5 receive program is working as expected.
At the moment we are not 100% sure if its the oximeter, usb/rs232 or the vb5 program.:)
Attached two images, the AA image is the transmitting PC and the 000 image is the receiving PC, showing the data as valid.
also there is a repetitive hex file for transmit tests.
  • OxiTestTx1.hex
Changed the text box to a rich text box to allow longer file display.
This image is that test file hex being received, all OK
Note: I have made the byte 5 either 35 or 3F, so that you see the text changing.
  • oxim2.bas
i tried to change the text box to be Rich one
NO LUCK !!!
i will go crazy now :)
the app is freezing and can't even stop the project from VB
something wrong with code made it to hang up
NO LUCK !!!
I dont believe there is a problem with my code, I have checked every which way without a problem.
The next step I would suggest is to download from the web a free PC comms program and use that connected to the Oximeter.
Let me know what you see.
free comms software - Pesquisa Google
Eric
BTW: do you have a model/type number for your Oximeter hardware.???
EDIT:
Using a free-ware RS232/UART data-logger program, I get this attached hex file, which confirms that my transmit and receive VB5's are OK.
Use a HEX viewer program to see the hex data.
  • OxiTestTx1.hex
there is no part number for it ... its common from many manufacturers
its USB to Comport actually as I described before here how it looks in Device Manager : Silicon Labs CP210x USB to UART Bridge
Thanks Eric ,,,
Thanks Eric ,,,
hi.
I looked at the Silicon Labs CP210x USB to UART Bridge, but its just a driver for usb/uart usage.
I would recommend that you try the Oximeter and VB5 programs with a regular PC/RS232 connection.
yeah i know its a driver to make a virtual comport
but do u mean try another Oximeter with comport !! ?? not mine ??
I mean get a PC that has a standard Serial [RS232] port and try the Oximeter you already have and use the VbB5 programs.
Did you download a free RS232 comms program and try that with the Oximeter.?
