applying solder paste from a jar
Hi
I thought I could put solder paste into syringe manually. I was so wrong. It just clogged up the syringe.
Besides buying solder paste in syringe, how can I apply solder paste onto my pcb accurately?
Currently I just use the tip of the clogged syringe to dab the paste onto the pads. I have foundthis method to be inaccurate and sometimes messy.
If you're having circuit boards made, order a solder paste stencil with the boards.
Line up the stencil to the board, put some solder paste on the stencil and use a credit card to squeegee the solder paste across the stencil openings.
I fill a small plastic syringe with solder paste.* The syringes I use are all plastic. The plunger tip is not rubber, but I am not sure that makes a difference. Generally, unless using a stencil, you will need to add a small amount of compatible liquid flux or other diluent. I use 99% isopropyl alcohol. I put a small amount of paste on a piece of aluminum foil, add the diluent (just a little) until it is more like ketchup, then use a small needle to apply tiny dots to the pads and proceed as usual. For very small SMD's, I use a reflow oven.
*It's quite hard to suck solder paste into the syringe. I fill the syringes from the back with the plunger removed (of course). With a fresh tub of paste, I fill several syringes, cap them tightly, and store in a freezer bag in a refrigerator (not freezer). You can also use whatever you have to put a small blob on the foil, if you don't have syringes.
