Receiving data from comport !!
You don't mention which version of VB you are using? The MSCOMM control was standard through VB 6.0 but if you are using VB.NET I suggest you start by reading this link. The actual code will differ between VB.NET and earlier versions of VB.
Ron
You will need to parse the data that is returned. I looked at the linked to .pdf yesterday. Unfortunately today at work that file is blocked by websense. Hopefully this evening I can look at it again. But if I recall what I read, you will want to parse the data. I knew I should have downloaded thet .pdf file and emailed it to myself at work. Oh well, looking at a busy day anyway. :(
As to VB I see it all the same. VB for DOS through the last version of VB.NET 2010. :)
Ron
Ok Ron
i am waiting you ;)
Thank you :)
I have cut down down a bigger program for this clip, it does work as the image shows.
It receives in binary format so that you can get control codes if required.
Delete & "." after the data print, that was for the test.
mmm thats didn't work
i tried many ways similar to ur code and nothings happened
But i got data in the textbox like " w~￾?￾.??.?￾?￾.ÿ?ÿ.?ÿ?.ÿ?.ÿ¸ÿ?.ÿ?.ÿ¸ÿ.?ÿ?ÿ.¸ÿ.?ÿ¸.ÿ?ÿ.￾ÿ￾ÿ.?ÿ.?ÿ?.ÿ?ÿ￾.ÿ?ÿ.?ÿ￾.ÿ?ÿ.?ÿ¸.ÿ?ÿ.￾ÿ?.ÿ￾ÿ.?ÿ?.ÿ?ÿ.¸ÿ?.ÿ?ÿ.?ÿ?.ÿ¸ÿ.?ÿ¸ÿ."
i tried many times :) with no luck at all
as i read in PDF file it support baud rate = 4800 and odd
i trid to changes the setting of the comport as well
I will change the code to suit 4800 baud and Odd parity.
Get back to you.
EDIT:
It works OK for me, I will recheck your earlier pdf.
EDIT2:
Checking that pdf shows that the data is not in ASCII format, so any characters printed will be nonsense.
Of the 5 bytes of data from the module, the individual bits of each byte have a 'meaning' assigned to them.
So you will have to capture the 5 bytes and then test each bit/s in turn and decode their meaning.
Can you do that OK.?
NOTE: Bit #7 of Byte #1 is the synchronisation bit, so you must test that bit in order to determine which byte is which.
i did that already with no luck ,,,
But as i understand from the PDF file i have to send a command to the device to get the data back ,,, may i am wrong
According to the pdf, the data output is continuous,
60 packets of 5 bytes/sec
This program will display the output in HEX bytes with a 'comma' in between each byte. It does work.
You will then have to sample each bit as I stated earlier.
Option Explicit
Dim X
Private Sub Form_Load()
MSComm1.CommPort = "2"
MSComm1.Settings = "4800,O,8,1"
MSComm1.InputLen = 0
MSComm1.PortOpen = True
End Sub
Private Static Sub MSComm1_OnComm()
Dim Data
Dim Xchr As String
Dim strlen As Byte
   Select Case MSComm1.CommEvent
        Case comEvReceive
            Dim Buffer As Variant
            Buffer = MSComm1.Input
            Data = (StrConv(Buffer, vbUnicode))
                    strlen = Len(Data)
            For X = 1 To strlen
            Xchr = Mid$(Data, X, 1)
            Xchr = Hex$(Asc(Xchr))
            Xchr = Right$("00" + Xchr, 2)
            Text1.SelStart = Len(Text1.Text)
            Text1.SelText = Xchr & "."
            Next X
    End Select
End Sub
Thank u Eric so much
yeah it works fine
and i got the input data :)
but its like = "B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2.B8.F2." etc
mmm is this fine according to the pdf file ?
as i imagined its not the data we should get
but we almost get the solution for this issue :)
many thanks :) :) :) :)
let me know if u have any idea for getting the exact data
Thanks again more than before ;)
yeah it works fine
I will set up a PC to transmit that string of hex bytes you have posted and in another PC try to decode the bytes into bits.
See if we can match what the pdf says.:) , let you know.
Added a simple subroutine to convert the received binary values to a Bit pattern.
You will have to test for Bit #7 in the string to determine the sync byte.
Image shows a test string print out,, data sent from another PC via the UARTs
Option Explicit
Dim X
Dim BitStr, BitStr2 As Variant
End Sub
Dim Data
Dim strchr As String
Dim strlen, valchr As Byte
        Case comEvReceive
            strlen = Len(Data)
            For X = 1 To strlen
            strchr = Mid$(Data, X, 2)
            valchr = Asc(strchr)
            Text1.SelText = Format(valchr, "000") & " > "
            Next X
 'convert from 'decimal' byte value to 8 bit pattern
            Bin2BinStr Str(valchr)
              Text1.SelText = BitStr & vbCrLf
    End Select
End Sub
Static Function Bin2BinStr(PrtVal As Integer)
'converts a 8 bit string value to 8 bits
Dim binmask, p As Integer
BitStr = String(8, "0")
 If PrtVal > 127 Then
    Mid$(BitStr, 1, 1) = "1"
    Else
    Mid$(BitStr, 1, 1) = "0"
 End If
    If PrtVal < 0 Then
    End If
 binmask = &H40
 For p = 2 To 8
    If PrtVal And binmask Then
    Mid$(BitStr, p, 1) = "1"
    End If
    binmask = binmask \ 2
 Next p
BitStr2 = BitStr
End Function
EDIT:
Added 2nd image showing how to get the sync byte
Edit the code to.
              If Left$(BitStr, 1) = "1" Then
              Text1.SelText = " sync"
              End If
              Text1.SelText = vbCrLf
Thank you sooo much for giving me time to help :)
i really appreciate it
now i corrected the code and gave results like this ( see the image )
mmm i don't have a good experience with that :(
see what u can help me with ;)
is this correct data we should get according to the PDF ?
Thanks again
Thanks again
Making some progress.
Exactly what is the unit that sends that data supposed to do.???
From your answer I may be able to help you.
BTW: I know its an Oximeter.! but I need to the meaning of the UART data blocks.
EDIT:
From your data image I would say you are losing some data.
I would capture from the MSCOMM input, say 15 readings into an array and then convert to bits.
the data i should get is reading like this ( see the pic )
this app is the one i got with the Oximeter ( its actually usb but has a virtual com port which i connect to )
its working fine with the application but with my project not yet :)
all i got is the only app + protocol communication in PDF
i don't know what to do
hi.
Capture a few seconds of UART data from the Oximeter to a file, use an array to save the 'raw' data and post the data file.
Can you do that.?
EDIT:
Added some notes to the protocol, these values are the ones of most interest
here it is
this text file includes the data for less than a minute ;)
check it out
  • spo2.txt
