Really quick question-mono audio socket
Sceadwian
Banned
Three leads generally means the socket has a left right and ground conductor? If he's only getting sound out of one earbud all he has to do is connect the left and right leads together.
forumlicker007
One of the bottom leg works as an internal switch for disconnecting speakers when earphone is plugged in.
Sceadwian
Banned
Woops, that's what I get for not looking at the supplied part description =\ I'm just full of stupid posts latley.
He could modify the headsets phono jack though. Solder bridge the L/R lines on the male side and both ears will get the mono signal. Just don't use too much solder.
Nigel Goodwin
Super Moderator
Most Helpful Member
I followed his link and checked, it's just a mono switched socket.
Almost certainly a moulded plug, easier to get the correct socket.
Sceadwian
Banned
Stereo headset jacks have their three connectors right there on the shaft of the plug, easy to slap a dab of solder on. Why buy a new plug when you just need a mono headset =) Easier to modify the headset than replace the jack.
spitso
connecting L and R together would work i suppose, but not always same headphones would be used.....so i suppose ill just have to buy a stereo plug DOOOH should have just done that in the first place.
thanks
audioguru
Most Helpful Member
No.
You need a stereo jack (socket), not a plug.
EE World Online Articles
Loading
