R.P.S's Rated Power Handling.
Screech
Is this rotary position sensor rated at 1 watt?
I ask because I don't understand it's specs.
see pic:
thanks.
see pic:
Yes, but bear in mind that's absolute maximum for the entire track, half the track would only be rated at 0.5W, and so on.
However, I would suggest running it at far less power!, I notice the spec advises using a high input impedance amplifer as a buffer!.
see pic:
Thanks Nigel, I will be using a lot less power then that.
I dont know what a high input impedance amplifer as a buffer is, but I will use the senor as a voltage divider hooked up to a LM3914 LED driver chip.
The Led driver will then switch on stuff.
That's fine!.
