Heidi
Dear friends,
The two coils of wire in the drawing below represent an ideal transformer, assuming that it has a turns ratio of 10:1.
When voltage source v1 is increasing from zero to its maximum value, the current i1 seems also to be positively increasing from zero to its maximum. During this time period, the resulting voltage v2 in the secondary coil seems to have a positive value that is increasing from zero to its maximum.
1. Is the voltage v2 the sum of mutual voltage and self-induced voltage?
2. Does the mutual voltage that is a result of increasing magnetic flux coming from the primary coil has a positive value? Does the self-induced voltage in coil 2 that is induced by the current i2 has a negative value, but the magnitude of the mutual voltage is larger than the self-induced voltage?
Thank you!
Thank you!
