PWM frequency problem PIC MicroC
Hello I want to generate a PWM for my application. I am using PIC16F1939, MicroC and PICkit 2 to burn the program.
Here's my code-
void interrupt()
if (TMR2IF_bit == 1)
CCPR1L = 100;
TMR2IF_bit = 0;
void main()
C1ON_bit = 0;
C2ON_bit = 0; // Disable Comparators
TRISC = 0XFF;
PR2 = 249;
CCP1CON = 12;
CCPR1L = 0;
TMR2IF_bit = 0;
T2CON = 0X04;
while (TMR2IF_bit == 0);
TMR2IF_bit = 0;
TRISC = 0X00;
TMR2IE_bit = 1;
GIE_bit = 1;
PEIE_bit = 1;
while(1)
//Do other stuff
I replaced old crystal with a new one still no change. Crystal is 20MHZ. Frequency I get on the CCP pin is 500HZ only where according to the calculations it should be 20 KHZ. Also I replaced PIC16F1939 with PIC16F877A.
Where could be the problem? Please help!
You might have the internal 32kHz oscillator selected. Try blinking an LED to work out the actual oscillator frequency.
I have selected HS oscillator and inserted 20MHz in the sidebar in MicroC. Is PICkit 2 overriding the settings? How to select HS oscillator in PICkit 2 and in MicroC.
With delay. If you try for 1 Hz and you get a flash every 150 seconds then you have the 32kHz oscillator.
Or, try switching to the internal oscillator. Use the 16MHz as it's nearest.
Thanks for your quick replies. I programmed the PIC with simple program-
PORTD= 0XFF;
delay_ms (10);
PORTD= 0X00;
delay_ms (10);
I am getting 1HZ blink while it should be with delay_ms (1000)? So I think PIC is being programmed with internal oscillator. But I have selected HS in MICROC config settings. Is PICkit 2 overriding config bits? Where can set them manually? I couldn't find any option?
Its in the project settings... Nothing to do with pickit2..
Thanks. I have tried it already. I think the crystal oscillator is not working. I got my program working by using internal oscillator. For those who want to know the settings, use - OSCCON = 0X7A for selecting 16MHZ internal oscillator ( May be for PIC16F1939 only. Check datasheet for other PICs). Thank you all. I will let you know when I'll replace the crystal.
