please suggest a DTMF generator chip.
pkshima
hi guys,
can someone suggest a cheap DTMF tone generator chip which can be interfaced with the computer thru the parallel (or other) port ?
need it to build a remote that can be operated hand held as well as plugged into the parallel port.
any other suggestions also welcome.
bye,
Shima
bogdanfirst
so you want to use a remote to control the robot, but then connect it to the computer and connect it trough the comuter to control the robot?
Pilot
Have a look at the HT9200 by Holtek
The data sheet is at...
Uses 4 data bits (in parallel mode) plus a couple of control bits so easy to control from the parallel port. You can also use serial control if you wish.
Minimum external components required to build a practical circuit.
If you want a DTMF receiver then look at the HT9170.. data sheet at....
Have Fun.
:lol:
pkshima
thx pilot for the link. but i guess i will have trouble locating the IC
in my area. also i guess this would b a bit pricy.
actually UM91214B is more common here but its datasheet is not available anywhere on the net. i just wanted to c if it can b interfaced to the compu.
thx anyway.
bogdanfirst c the other post.
pkshima
great pal !!!!!!
but the datasheet doesnt make clear whether the chip can b interfaced with a microcontroller/computer. what do u say can t be ?
thx a lot again,
Pradeep K. Shima
stu_dale
Hi.
Does any one know of where i could find a simple circuit that makes use of the HT9200 and HT9170.
i need to build an encoder and decoder for a project at college, and so far have had trobble finding any circuits ont the internet.
Thanks for any reply.
Stu
