I am in the final stages of debugging my Pic18F2xJ11 chip and I decided to give the in-circuit debugging a try. It works; however the animation speed when using animate via MPLAB C18 directly with the chip is very slow. For instance a simple while loop for the GO_DONE bit of the ADC converter takes so long I give up waiting. The cpu is not even running at 50% and I am getting around 2 lines of code per second animation speed.
There is no option for animation speed in MPLAB when in this debugging mode in the normal options menu so decided to post here to see if maybe there is something I am missing? The chip is nominally clocked at 4mhz, but I don't think that matters when using the debugger in this way.
Any ideas what I can do to speed up this animation speed?
T
T
