I'm new here and in C18... So, i was trying to do a clock, and here's my code:
How can I connect a keypad-phone to my code and print at the display the numbers that the user choose on the keypad? Assuming that my keypad is conected on PORTB. :|
Thanks for any help.
#include "stdlib.h"
#include "p18f46k20.h"
#include "delays.h"
#include"stdio.h"
int x,z;
int unidadesegundo, dezenasegundo, unidademinuto, dezenaminuto, unidadehora, dezenahora;
unsigned int convert_7s(int num){
int vector[11] = {0b01000000, 0b11111001, 0b00100100, 0b00110000, 0b00011001, 0b00010010, 0b00000010, 0b11011000, 0b00000000, 0b00011000};
return vector[num];
unsigned int habilit_port(int display){
int vector[6] = {0b00100000, 0b00010000, 0b00001000, 0b00000100, 0b00000010, 0b00000001};
return vector[display];
void habilit_port_number(unsigned int port, int num){
switch(port){
case 1:{
PORTA = convert_7s(num);
break;
case 2:{
PORTB = convert_7s(num);
break;
case 3:{
PORTC = convert_7s(num);
break;
case 4:{
PORTD = convert_7s(num);
break;
void habilit_port_habilit(unsigned int port, int display_habilit){
switch(port){
case 1:{
PORTA = habilit_port(display_habilit);
break;
case 2:{
PORTB = habilit_port(display_habilit);
break;
case 3:{
PORTC = habilita_port(display_habilit);
break;
case 4:{
PORTD = habilita_port(display_habilit);
break;
void desabilit_port(unsigned int port){
switch(port){
case 1:{
PORTA = 0x00;
break;
case 2:{
PORTB = 0x00;
break;
case 3:{
PORTC = 0x00;
break;
case 4:{
PORTD = 0x00;
break;
void reset_numbers(int *num1, int *num2, int *num3, int *num4, int *num5, int *num6){
*num1=0;
*num2=0;
*num3=0;
*num4=0;
*num5=0;
*num6=0;
void write_display(int *num1, int *num2, int *num3, int *num4, int *num5, int *num6, int port1, int port2){
//Segundos
//Unidade
habilit_port_number(port1, *num1);
habilit_port_habilit(port2, 0);
Delay1KTCYx(1);
desabilit_port(4);
//Dezena
habilit_port_number(port1, *num2);
habilit_port_habilit(port2, 1);
if(*num1==10){
(*num2)++;
Delay1KTCYx(1);
desabilit_port(4);
if(*num1==10){
(*num1)=0;
//Minutos
//Unidade
habilit_port_number(port1, *num3);
habilit_port_habilit(port2, 2);
if(*num2==6){
(*num3)++;
Delay1KTCYx(1);
desabilit_port(4);
if(*num2==6){
(*num2)=0;
//Dezena
habilit_port_number(port1, *num4);
habilit_port_habilit(port2, 3);
if(*num3==10){
(*num4)++;
Delay1KTCYx(1);
desabilit_port(4);
if(*num3==10){
(*num3)=0;
//Horas
//Unidade
habilit_port_number(port1, *num5);
habilit_port_habilit(port2, 4);
if(*num4==6){
(*num5)++;
Delay1KTCYx(1);
desabilit_port(4);
if(*num4==6){
(*num4)=0;
//Dezena
if((*num5)==5 && (*num6)==2){
*num1=0;
*num2=0;
*num3=0;
*num4=0;
*num5=0;
*num6=0;
}else{
habilit_port_number(port1, *num6);
habilit_port_habilit(port2, 5);
if((*num5)==10){
(*num6)++;
Delay1KTCYx(1);
desabilit_port(4);
void main(void){
TRISC= 0x00;
TRISD= 0b00000000;
PORTC=0xFF;
PORTD= 0b00000000;
reset_numbers(&unidadesegundo, &dezenasegundo, &unidademinuto, &dezenaminuto, &unidadehora, &dezenahora);
while(1){
int i;
for(i=0;i<40;i++){
write_display(&unidadesegundo, &dezenasegundo, &unidademinuto, &dezenaminuto, &unidadehora, &dezenahora, 3, 4);
desabilit_port(4);
if(i==39){
unidadesegundo++;
