PIC18F46K20 with MPLAB + C18
bla
I'm new here and in C18... So, i was trying to do a clock, and here's my code:
#include "stdlib.h"
#include "p18f46k20.h"
#include "delays.h"
#include"stdio.h"
int x,z;
int unidadesegundo, dezenasegundo, unidademinuto, dezenaminuto, unidadehora, dezenahora;
unsigned int convert_7s(int num){
	int vector[11] = {0b01000000, 0b11111001, 0b00100100, 0b00110000, 0b00011001, 0b00010010, 0b00000010, 0b11011000, 0b00000000, 0b00011000};
	return vector[num];
unsigned int habilit_port(int display){
	int vector[6] = {0b00100000, 0b00010000, 0b00001000, 0b00000100, 0b00000010, 0b00000001};
	return vector[display];
void habilit_port_number(unsigned int port, int num){
	switch(port){
		case 1:{
			PORTA = convert_7s(num);
			break;
		case 2:{
			PORTB = convert_7s(num);
			break;
		case 3:{
			PORTC = convert_7s(num);
			break;
		case 4:{
			PORTD = convert_7s(num);
			break;
void habilit_port_habilit(unsigned int port, int display_habilit){
	switch(port){
		case 1:{
			PORTA = habilit_port(display_habilit);
			break;
		case 2:{
			PORTB = habilit_port(display_habilit);
			break;
		case 3:{
			PORTC = habilita_port(display_habilit);
			break;
		case 4:{
			PORTD = habilita_port(display_habilit);
			break;
void desabilit_port(unsigned int port){
	switch(port){
		case 1:{
			PORTA = 0x00;
			break;
		case 2:{
			PORTB = 0x00;
			break;
		case 3:{
			PORTC = 0x00;
			break;
		case 4:{
			PORTD = 0x00;
			break;
void reset_numbers(int *num1, int *num2, int *num3, int *num4, int *num5, int *num6){
	*num1=0;
	*num2=0;
	*num3=0;
	*num4=0;
	*num5=0;
	*num6=0;
void write_display(int *num1, int *num2, int *num3, int *num4, int *num5, int *num6, int port1, int port2){
//Segundos
	//Unidade
	habilit_port_number(port1, *num1);
	habilit_port_habilit(port2, 0);
	Delay1KTCYx(1);
	desabilit_port(4);
	//Dezena
	habilit_port_number(port1, *num2);
	habilit_port_habilit(port2, 1);
	if(*num1==10){
		(*num2)++;
	Delay1KTCYx(1);
	desabilit_port(4);
	if(*num1==10){
		(*num1)=0;
//Minutos
	//Unidade
	habilit_port_number(port1, *num3);
	habilit_port_habilit(port2, 2);
	if(*num2==6){
		(*num3)++;
	Delay1KTCYx(1);
	desabilit_port(4);
	if(*num2==6){
		(*num2)=0;
	//Dezena
	habilit_port_number(port1, *num4);
	habilit_port_habilit(port2, 3);
	if(*num3==10){
		(*num4)++;
	Delay1KTCYx(1);
	desabilit_port(4);
	if(*num3==10){
		(*num3)=0;
//Horas
	//Unidade
	habilit_port_number(port1, *num5);
	habilit_port_habilit(port2, 4);
	if(*num4==6){
		(*num5)++;
	Delay1KTCYx(1);
	desabilit_port(4);
	if(*num4==6){
		(*num4)=0;
	//Dezena
	if((*num5)==5 && (*num6)==2){
			*num1=0;
			*num2=0;
			*num3=0;
			*num4=0;
			*num5=0;
			*num6=0;
	}else{
		habilit_port_number(port1, *num6);
		habilit_port_habilit(port2, 5);
		if((*num5)==10){
				(*num6)++;
		Delay1KTCYx(1);
		desabilit_port(4);
void main(void){
	TRISC= 0x00;
	TRISD= 0b00000000;
	PORTC=0xFF;
	PORTD= 0b00000000;
	reset_numbers(&unidadesegundo, &dezenasegundo, &unidademinuto, &dezenaminuto, &unidadehora, &dezenahora);
	while(1){
		int i;
		for(i=0;i<40;i++){
			write_display(&unidadesegundo, &dezenasegundo, &unidademinuto, &dezenaminuto, &unidadehora, &dezenahora, 3, 4);
			desabilit_port(4);
			if(i==39){
				unidadesegundo++;
How can I connect a keypad-phone to my code and print at the display the numbers that the user choose on the keypad? Assuming that my keypad is conected on PORTB. :|
Thanks for any help.
MPLAB C18 v3.22 (demo)
Copyright 2000-2008 Microchip Technology Inc.
Days remaining until demo becomes feature limited:  11
C:\MCC18\h\[COLOR=Red][B]p18f4620.h[/B][/COLOR]:43:Error [1109] type mismatch in redeclaration of 'PORTAbit
Thinking you grabbed some code and forgot to change the processor include file name.
Look for this line in your code and fix it.
#include <p18f4620.h>
