This small proj. might be useful for some people...
Basically it's a square wave dds generator 1-255 Hz with a pic micro,a crystal & caps, 8 pos dip switch.
The desired output frequency is determined by the switches ( binary like).
My inspiration came from mr. RB site :
https://www.romanblack.com/onesec/High_Acc_Timing.htm#decfreq
The source code mikrocpro v5.8.0 compiler :
// square wave dds generator 1-255 Hz
// 16F628 @ 16 MHz
// mikroc pro v5.8.0
// 8 pos DIP switch connected to PORTB
// |ON RB7 RB6 RB5 RB4 RB3 RB2 RB1 RB0 |
// | |SW1|SW2|SW3|SW4|SW5|SW6|SW7|SW8|
// | GND GND GND GND GND GND GND GND |
// desired output frequency is determined by the switches ( binary like)
// 1Hz -> 00000001 |SW1-7 OFF, SW8 ON|
// 7Hz -> 00000111 |SW1-5 OFF, SW6 ON, SW7 ON, SW8 ON|
// 255Hz -> 11111111 |SW1-8 ON
#define HZ 16000000 // 16MHz HS xtal = 16000000
#define TOGGLE (HZ * 125)
// RAM vars
unsigned char sw_old,sw_new ;
volatile unsigned long accum;
volatile unsigned long freqHz;
void interrupt(void)
PIR1.TMR2IF = 0; // clear TMR2 roll flag
accum += freqHz; // decimal DDS addition into accumulator
if(accum >= TOGGLE)
PORTA = ~ PORTA ; // toggle output port to make frequency
accum -= TOGGLE; // decimal bresenham subtraction, keep remainder
void main(void)
// setup PIC 16F628
CMCON = 0x07; // comparators OFF
PORTA = 0b00000000; // porta is freq output
TRISA = 0b00000000;
TRISB = 0b11111111; // PORTB all inputs
OPTION_REG = 0 ; // weak pull-ups on
// setup TMR2 to roll every 200 ticks
T2CON = 0b00000100; // TMR2 ON, 1:1 prescale
PR2 = (100-1); // TMR2 int occurs every 100 ticks
INTCON = 0b11000000; // GIE = ON, PEIE = ON
PIE1.TMR2IE = 0; // TMR2 interrupt OFF
sw_old = ~PORTB ; // read switches
freqHz = ( unsigned long ) sw_old * 100000 ; // set the desired fq
accum = 0; // clear var
PORTA = 0;
PIE1.TMR2IE = 1; // TMR2 interrupt ON
for(;;)
sw_new = ~PORTB ; // read switches
if(sw_new != sw_old ) // new fq ?
freqHz = ( unsigned long ) sw_new * 100000 ; // set the desired fq
sw_old = ~PORTB ; // save the status of the switches
PORTA = 0; //
