Beefer3
Hey everyone
Can someone help out on the following code?
The first two IF THEN statements work but, the switch IF THEN statement does not.
When I run the code with the first two IF THEN statements commented out, the switch IF THEN statement is recognized.
Also, if I hold down the switch and press A or B on my terminal program, the switch IF THEN statement is recognized.
I am completely confused as to why it does not work.
Any help is greatly appreciated.
Here is the code:
DEVICE 16F84A
INCLUDE "MODEDEFS.BAS"
PORTA = %10111
PORTB = %00000000
Cls
Print AT 1, 1, " WELCOME"
Dim SERDATA As Byte
SINPUT:
SERIN PORTA.4, 396, [SERDATA]
If SERDATA = "A" Then
SEROUT PORTA.3,396, ["SENDING THE LETTER A"]
Cls
Print AT 1, 1, "SENDING THE"
Print AT 2, 1, "LETTER A"
Else
End If
If SERDATA = "B" Then
SEROUT PORTA.3,396, ["SENDING THE LETTER B"]
Cls
Print AT 2, 1, "LETTER B"
Else
End If
IF PORTA.2 = 1 THEN
Cls
Print AT 1, 1, "SWITCH PUSHED"
SEROUT PORTA.3,396,[ "SWITCH PUSHED"]
Else
End If
GOTO SINPUT
End
Here is the code:
DEVICE 16F84A
PORTA = %10111
PORTB = %00000000
Cls
Dim SERDATA As Byte
SINPUT:
Cls
Else
End If
Cls
Else
End If
IF PORTA.2 = 1 THEN
Cls
Else
End If
GOTO SINPUT
End
