PIC 18 series in circuit programmer?
wsc
Hey all, newbie to the forum here.
I am working on a product and am looking for some advice. I've used PIC 16 series chips a good deal and an looking to move up to the 18 series, specifically the 18F452 because I believe the 16bit core plus higher speed could be valuable to my product.
What I am after is an in circuit programmer for these chips. I am using a Maxim MAX662 flash voltage generator to program 16F877 and the like. I was hoping it would be easy to migrate this technique to the 18 series. Can anyone offer me some advice? Thanks 8)
I've not used the 18 series chips, but no doubt MicroChip have datasheets and application notes which will tell you all you need, check their website!.
Using a MAX662 seems a very difficult way of doing in-circuit programming, a simple serial interface can be used for a bootloader, the 16F877 supports this, and (as far as I know) so do most of the 18 series chips. It also provides you with a serial port, which can be used elsewhere in your application.
In the past I have used PP18
Works great, his schaer programer design works great to, just use good transistors.
Have fun
Kent
There are plenty of PIC18 bootloaders. Just do a web search for "PIC18 bootloader"
The PIC18 has a multiplication op that handles 16 bit numbers. I don't believe it can properly be called a 16 bit core, however.
I like the speed & size of the PIC18F 252/452. I do everything in HiTech PIC-C; the expanded command set in the 18 series is supposed to work better with C though I have no way to verify this.
I expect that taking advantage of the expanded command set when programming in assembly will require additional learning time. I believe the PIC16 commands are still all there, though.
What else would you call it?, it has a 16 bit wide program core, all instructions are 16 bits long (all 55 of them). The 16F series are 14 bit core, and have 35 14 bit long instructions.
It's still an 8 bit processor though!, as are the 14 bit and 12 bit cores.
