Pic 16f877
uaefame
Hello everyone,
I am not a pro electrical and this might be a simple question.
Is placing 2 capacitor 0.1uf necessary between Vdd and ground?
Q1> If yes why?
Q2> If yes shall i place 1 or 2 capacitors?
See attachment to understand more.
Hello everyone,
Q1> If yes why?
we definitely Thank you as you are rehearsing our knowledge.
1. YES, the cap is necessary to bypass all the electrical HF activity created by the chip, thus preventing noise on the Vdd line.
2 One would do if you are shorting the lines across the chip as they are on either side of the chip. If independently fed, better have two caps.
Thanks mvs,
This circuit will be used for driving a servo motor. Many of you already know this :) See attachement if interested in my diagram.
Prior driving a servo motor, I am interested in testing it using Oscilloscope. Therefore, I connected RB0 to oscilloscope to see 2ms on time and 18ms off time. My problem I don’t read anything from the oscilloscope anyone knows why?
The codes are here
;                           16F877 PWM Program
		include	"p16f877.inc"
		errorlevel	-302
		radix	dec
	__CONFIG _CP_OFF & _DEBUG_ON & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _HS_OSC & _LVP_OFF & _CPD_OFF
		cblock	20h
OnTime:2
OffTime:2
		endc
		cblock	71h
int_work
int_status
int_pclath
		endc
		org     0h
		nop
		goto    start
		nop
		nop
		org 	04h
interrupt	movwf	int_work
		swapf	STATUS,W
		movwf	int_status
		bcf	STATUS,RP0
		bcf	STATUS,RP1
		movfw	PCLATH
		movwf	int_pclath
		clrf	PCLATH
		btfsc	PORTB,0
		goto	TurnOff
; turn on the output and write the on time
		nop;		delay to make both path identical
		bsf	PORTB,0;<<<<<<<<<< Break Point
		movfw	OnTime+1
		movwf	CCPR1H
		movfw	OnTime
		movwf	CCPR1L
		goto	DonePWM
TurnOff		bcf	PORTB,0;<<<<<<<<<< Break Point
		movfw	OffTime+1
		movwf	CCPR1H
		movfw	OffTime
		movwf	CCPR1L
DonePWM
		bcf	PIR1,CCP1IF;	reset special event trigger interupt
		movfw	int_pclath
		movwf	PCLATH
		swapf	int_status,W
		movwf	STATUS
		swapf	int_work,F;	swap to file
		swapf	int_work,W;	swap to work
		retfie
start		bsf	STATUS,RP0
		bcf	STATUS,RP1
		bsf	STATUS,IRP;	all indirest access is to 100h - 1ffh
		 movlw	(0<<NOT_RBPU|0<<INTEDG|0<<T0CS|0<<T0SE|0<<PSA|B'000'<<PS0)
		movwf	OPTION_REG
		movlw	b'11111110'
		movwf	TRISB
		bcf	STATUS,RP0
		movlw	(b'01'<<T1CKPS0|0<<T1OSCEN|0<<NOT_T1SYNC|0<<TMR1CS|1<<TMR1ON)
		movwf	T1CON;		enable timer 1
		movlw	low(5000)
		movwf	CCPR1L
		movwf	OnTime
		movlw	high(5000)
		movwf	CCPR1H
		movwf	OnTime+1
		movlw	low(45000)
		movwf	OffTime
		movlw	high(45000)
		movwf	OffTime+1
		movlw	(0<<CCP1X|0<<CCP1Y|b'1011'<<CCP1M0);	enable special event trigger on CCP1
		movwf	CCP1CON;
		bsf	STATUS,RP0
		bsf	PIE1,CCP1IE;	enable CCP1 interupt
		bcf	STATUS,RP0
		movlw	(1<<GIE|1<<PEIE|0<<T0IE|0<<INTE|0<<RBIE|0<<T0IF|0<<INTF|0<<RBIF)
		movwf	INTCON;		enable Peripheral interupts
Loop
		goto	Loop
END
I start a new thread here because the title matches the problem :) I used to ask this in a thread called 16F818 which causes alot of confusion. Now the title matches the problem I hope no more confusion.
Hmm, I wanted to solve the problem above.
So, I just paused and said let me build a circuit that turn LED on and off. Simple Right.
My problem is how can I tell the PIC i am using an internal CLOCK of 20MHz?
Here are my codes
    list      p=p16F877             ; list directive to define processor
    #include <p16F877.inc>         ; processor specific variable definitions
	cblock 0x20
	d1
	d2
	d3
	endc
org 0x00
movlw (0<<T0CS)
movwf OPTION_REG
bsf STATUS, RP0
bcf STATUS, RP1
movlw 0x00
movwf TRISB
bcf STATUS,RP0
START movlw 0x00
	movwf PORTB
	call Delay1sec
	movlw 0x01
	movwf PORTB
	call Delay5sec
	goto START
Delay1sec
			;4999993 cycles
	movlw	0x2C
	movwf	d1
	movlw	0xE7
	movwf	d2
	movlw	0x0B
	movwf	d3
Delay1sec_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay1sec_0
			;3 cycles
	goto	$+1
	nop
			;4 cycles (including call)
	return
Delay5sec
			;4999993 cycles
	movlw	0x2C
	movwf	d1
	movlw	0xE7
	movwf	d2
	movlw	0x0B
	movwf	d3
Delay5sec_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay5sec_0
			;3 cycles
	goto	$+1
	nop
	return
END
The problem in the codes is I didn't set the internal clock to 20Mhz. Anyknow what i should do?
You don't set the clock speed anywhere, you write the code to use the clock speed you choose. In particular the delay routines in the posted code need to be written specifically for the clock speed - and if generated by the PICList delay code generator you have to input the clock speed.
I did it with a PIC delay generator and specified the 20Mhz frequency value.
My question is how I can tell the PIC that I am using 20MHz internal crystal?
OMG, I think what is going wrong PIC16F877 doesn't have an internal clock! I see why the servo didn't rotate. Tommorrow I will go get 20Mhz oscillator. What a discovery :(.
You need a 20MHz crystal, two small capacitors, and to set the oscillator config fuses to HS.
what is OP?
Thanks everyone for replying :)
Q> These codes are taking the motor to one direction suppose after 2second I want it to shift or go to other direction? How can I do this using Interrputs?
Any ideas?
Hello again,
Here is my new diagram I only added 20Mhz crystal and 2X22pf capacitor, I am trying to control a servo motor from pin RB0 of the PIC16F877. Nothing happen, You think my diagram is wrong? or the codes? I posted already?
Thanks in advance
Hello again,
Thanks in advance
You have a pulldown on MCLR. That's backward. Put a pullup - the resistor should connect to VCC/5V.
That might work as long as the programmer is connected, overriding the pulldown, but the second you disconnect it the PIC is in RESET. Nothing happens while in reset. MCLR must go high for the chip to run.
Thanks futz for replying,
Here is the new diagram, The problem now I am reading 5V continuous 5V from RB0 from my oscilloscope? Any idea what wrong?
General Question> why there is 2 power supply and 2 ground in this PIC, can i only connect one of them?
Thanks in advance
Hello again,
Anyone like my new avatar :).
To the main point, the codes and the circuit is fine, I reprogrammed it and now it's working fine I am reading 2ms from oscilloscope :).
I am only controlling one output. I want to send same codes to three output any idea?
Thanks in advance
I am trying to control 2 servo motor at the same time and do excatly the same thing. I know just doing normal codes like
start
movlw b'00000011'
movwf PORTB
call delay1ms450us
movlw b'00000000'
movwf PORTB
call delay18ms550us
goto start
But I want to control it using interrupt
here is editted pommies code for interrupt but it's not working anyidea?
		errorlevel	-302
		radix	dec
		cblock	20h
OnTime:2
OffTime:2
		endc
		cblock	71h
int_work
int_status
int_pclath
		endc
		org     0h
		nop
		goto    start
		nop
		nop
		org 	04h
		swapf	STATUS,W
		movwf	int_status
		bcf	STATUS,RP0
		bcf	STATUS,RP1
		movfw	PCLATH
		movwf	int_pclath
		clrf	PCLATH
		btfsc	PORTB,0
		goto	TurnOff
		bsf	PORTB,0
		bsf PORTB,1;<<<<<<<<<< Break Point
		movfw	OnTime+1
		movwf	CCPR1H
		movfw	OnTime
		movwf	CCPR1L
		goto	DonePWM
TurnOff		bcf	PORTB,0
			bcf PORTB,1;<<<<<<<<<< Break Point
		movfw	OffTime+1
		movwf	CCPR1H
		movfw	OffTime
		movwf	CCPR1L
DonePWM
		movfw	int_pclath
		movwf	PCLATH
		swapf	int_status,W
		movwf	STATUS
		retfie
		bcf	STATUS,RP1
		movwf	OPTION_REG
		movlw	b'11111100'
		movwf	TRISB
		bcf	STATUS,RP0
		movlw	low(5000)
		movwf	CCPR1L
		movwf	OnTime
		movlw	high(5000)
		movwf	CCPR1H
		movwf	OnTime+1
		movlw	low(45000)
		movwf	OffTime
		movlw	high(45000)
		movwf	OffTime+1
		movwf	CCP1CON;
		bsf	STATUS,RP0
		bcf	STATUS,RP0
Loop
		goto	Loop
END
