haxan
Hi, i am trying to make a parallel communication protocol which uses 10 pins from one controller and 10 from the other one. 8 pins are to transfer a byte of data and 2 pins for data control. I have successfully made one way communication from Master to Slave. however i am getting problems when sending data back to the Master. The master sends a command to the slave and the slave from the frame knows how many bytes to send back to the master. So basically master sends a command and then waits for the slave to send a certain number of bytes for which the master is waiting.
The problem occurs when i try to make the slave port for output (which is previously in input mode to read data bytes coming from master)
My frame structure is:
[START BITS][ADDRESS][COMMAND][(n) number of bytes to receive][(m) number of bytes to transmit][(n) bytes][(m) bytes][STOP BITS]
P_OM = means the slave data control pin.
P_SM = means the master data control pin.
I am using PIC24FJ128GA010 for MASTER
and
PIC18F4520 for SLAVE.
Please kindly help me. I have been stuck with this for two days now
I have tried giving delays etc but doesn't work.
(Note: I get logic contention error in simulation, which actually means that at some point, both the pins have different voltages and both are set to output, which should not happen as i tend to make one port into input first and then try to read byte)
Master Code:
SLAVE CODE:
and
Master Code:
#include "TCPIP Stack/TCPIP.h"
#include "P_Communication.h"
---------------- [ PARALLEL COMMUNICATION LAYER ] -----------------------
~~~~ [ BEGIN ] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Conventions:
-- P_ means Parallel Communication (Function, Variable, Definition)
-- SM (connected with ethernet)
-- OM (connected with RS-485 Data Bus)
/*---- [ Parallel Communication Variables ] -----------------*/
BYTE P_ADDRESS;
BYTE P_COMMAND;
BYTE P_Rec_nbytes;
BYTE P_Trans_mbytes;
BYTE P_RecData[100];
BYTE P_TransData[100];
BYTE *P_RecPtr = &P_RecData[0];
BYTE *P_TransPtr = &P_TransData[0];
BYTE P_PORT_VAL = 0x00;
unsigned long P_timeout = 0; // Timeout Counter
unsigned char P_timedout = 0; // Timed out Flag
char COMM_P = 0;
char P_SM_Communication(
BYTE address,
BYTE command,
BYTE n_Transmit,
BYTE m_Receive,
BYTE *n_Bytes,
BYTE *m_Bytes
/* FRAME STRUCTURE
[STARTBITS] [ADDRESS] [COMMAND] [N-Bytes to Transmit] [M-Bytes to Receive] [N-BYTES] [M-BYTES] [STOPBITS]
BYTE i = 0;
P_Init();
if(P_OM == 0) // OM can take request
P_timedout = 0;
COMM_P = P_SendByte(P_START_BITS);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
COMM_P = P_SendByte(address);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
COMM_P = P_SendByte(command);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
COMM_P = P_SendByte(n_Transmit);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
COMM_P = P_SendByte(m_Receive);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
for(i = 0; i < n_Transmit; i++)
COMM_P = P_SendByte(n_Bytes[i]);
for(i = 0; i < m_Receive; i++)
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{m_Bytes[i] = COMM_P;}
COMM_P = P_SendByte(P_STOP_BITS);
else if(COMM_P == P_SUCCESSFUL){return P_SUCCESSFUL;}
else{return P_UNSUCCESSFUL;}
return P_NOTHING;
char P_SendByte(BYTE data)
P_timeout = 0;
while(P_OM != 0){if(P_CheckTimeout() == 1){return P_TIMED_OUT;}}
P_PORT_VAL = data;
P_PORT(0);
P_SM = 1;
P_timeout = 0;
while(P_OM != 1){if(P_CheckTimeout() == 1){return P_TIMED_OUT;}}
P_SM = 0;
BYTE P_ReadByte(void)
P_PORT(1);
P_SM = 0;
P_timeout = 0;
P_PORT_VAL = P_PORT(1);
P_SM = 1;
P_timeout = 0;
P_SM = 0;
return P_PORT_VAL;
void P_Init(void)
P_PORT(1);
P_TRIS_SM = 0;
P_TRIS_OM = 1;
P_SM = 0;
P_timeout = 0;
BYTE P_PORT(unsigned char dir)
if(dir == 0)
P_TRIS0 = 0;
P_TRIS1 = 0;
P_TRIS2 = 0;
P_TRIS3 = 0;
P_TRIS4 = 0;
P_TRIS5 = 0;
P_TRIS6 = 0;
P_TRIS7 = 0;
P_PORT0 = ((P_PORT_VAL & 0b00000001) > 0)? 1 : 0;
P_PORT1 = ((P_PORT_VAL & 0b00000010) > 0)? 1 : 0;
P_PORT2 = ((P_PORT_VAL & 0b00000100) > 0)? 1 : 0;
P_PORT3 = ((P_PORT_VAL & 0b00001000) > 0)? 1 : 0;
P_PORT4 = ((P_PORT_VAL & 0b00010000) > 0)? 1 : 0;
P_PORT5 = ((P_PORT_VAL & 0b00100000) > 0)? 1 : 0;
P_PORT6 = ((P_PORT_VAL & 0b01000000) > 0)? 1 : 0;
P_PORT7 = ((P_PORT_VAL & 0b10000000) > 0)? 1 : 0;
else if(dir == 1)
P_TRIS0 = 1;
P_TRIS1 = 1;
P_TRIS2 = 1;
P_TRIS3 = 1;
P_TRIS4 = 1;
P_TRIS5 = 1;
P_TRIS6 = 1;
P_TRIS7 = 1;
P_PORT_VAL = (0x00 | (P_PORT0 | P_PORT1 << 1 | P_PORT2 << 2 | P_PORT3 << 3 | P_PORT4 << 4 | P_PORT5 << 5 | P_PORT6 << 6 | P_PORT7 << 7));
return P_PORT_VAL;
char P_CheckTimeout(void)
if(P_timeout > 200000){P_timedout = 1;P_Init();return 1;}
P_timeout++;
return 0;
~~~~ [ END ] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
SLAVE CODE:
#include <p18cxxx.h>
#include <delays.h>
#include "RS_comm.h"
#include "../Commands.def"
Conventions:
BYTE P_ADDRESS;
BYTE P_COMMAND;
BYTE P_Rec_nbytes;
char COMM_P = 0;
char COMM_R;
char P_OM_Communication(
BYTE *n_Bytes, // Ptr to Receive n Bytes and store them
BYTE *m_Bytes // Ptr to Transmit m Bytes back
/* FRAME STRUCTURE
[STARTBITS] [ADDRESS] [COMMAND] [N-Bytes to Receive] [M-Bytes to Transmit] [N-BYTES] [M-BYTES] [STOPBITS]
BYTE i = 0;
P_Init();
if(P_SM == 1) // SM wants to communicate
P_timedout = 0;
if(COMM_P != P_START_BITS)
return P_NOTHING;
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{P_ADDRESS = COMM_P;}
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{P_COMMAND = COMM_P;}
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{P_Rec_nbytes = COMM_P;}
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{P_Trans_mbytes = COMM_P;}
for(i = 0; i < P_Rec_nbytes; i++)
COMM_P = P_ReadByte();if(COMM_P == P_TIMED_OUT && P_timedout == 1){return P_TIMED_OUT;}else{n_Bytes[i] = COMM_P;}
COMM_R = RS_M_Communication(P_ADDRESS,P_COMMAND,P_Rec_nbytes,P_Trans_mbytes,n_Bytes,m_Bytes);
if(COMM_R == RS_SUCCESSFUL)
for(i = 0; i < P_Trans_mbytes; i++)
COMM_P = P_SendByte(m_Bytes[i]);if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
PORTGbits.RG0 ^= 1;
else if(COMM_R == RS_COMMAND_INVALID){return P_COMMAND_INVALID;}
else if(COMM_R == RS_TIMED_OUT){return P_TIMED_OUT;}
PORTF = COMM_P;
if(COMM_P == P_STOP_BITS){return P_SUCCESSFUL;}
else if(COMM_P == P_TIMED_OUT){return P_TIMED_OUT;}
else return P_NOTHING;
P_OM = 0; // NEW EDITION
P_timeout = 0;
while(P_SM != 0){if(P_CheckTimeout() == 1){return P_TIMED_OUT;}}
P_PORT_VAL = data;
Delay10KTCYx(1);
P_PORT(0);
Delay10KTCYx(1);
P_OM = 1;
P_timeout = 0;
while(P_SM != 1){if(P_CheckTimeout() == 1){return P_TIMED_OUT;}}
P_OM = 0;
P_OM = 0;
P_timeout = 0;
P_OM = 1;
P_timeout = 0;
P_OM = 0;
return P_PORT_VAL;
void P_Init(void)
P_PORT(1);
P_TRIS_SM = 1;
P_TRIS_OM = 0;
P_OM = 0;
P_timeout = 0;
if(dir == 0)
P_TRIS0 = 0;
P_TRIS1 = 0;
P_TRIS2 = 0;
P_TRIS3 = 0;
P_TRIS4 = 0;
P_TRIS5 = 0;
P_TRIS6 = 0;
P_TRIS7 = 0;
else if(dir == 1)
P_TRIS0 = 1;
P_TRIS1 = 1;
P_TRIS2 = 1;
P_TRIS3 = 1;
P_TRIS4 = 1;
P_TRIS5 = 1;
P_TRIS6 = 1;
P_TRIS7 = 1;
return P_PORT_VAL;
if(P_timeout > 2000000){P_timedout = 1;P_Init();return 1;}
P_timeout++;
return 0;
--------------------- [ COMMUNICATION LAYER ] ---------------------------
