op amp comparator circuit
MrDEB
working on a comparator circuit which measures two different voltages on two seperate op amps then using a NAND gate , if both op amp outputs are same then output drives LED (going to be a 400 ohm relay)
forgot pic
oups got to quick
it works in LT spice
How about using two open-collector voltage comparators like **broken link removed**s? Set one up to switch high when it's input is >3V; set the other up to switch high when it's input is >4V. Wire the two outputs together to a common pull-up resistor. The combined output will be high if and only if both comparators are above their respective trip points.
That would be too easy
besides I have several LM324's on hand that I want to use.
have similar project using same LM342 (had 20 units given to me)
hi
You could use a couple of diodes and resistor to make an OR gate to replace the logic ic.
hi
Looks like he used two NAND gates to make an AND gate, not a OR gate, both inputs need to be logic 1, or did I miss something?
Ok, so three diodes then :)
Two diodes can be used to make either an OR or an AND, whats the problem.?
Why dont you suggest to the OP a way of solving the problem rather than nit picking my humble submission.:rolleyes:
hi Deb
Please post your LTS asc file and I will add diodes as required.
Confirm the operating sense of the relay drive transistor that you require.:)
Sorry Eric, no offense to you, you did say or gate. Not to negate your input. My apologies. :)
consider this.:)
IF the OP had wanted the relay to denenergise when either of the comp outputs had gone low then it would be an OR gate.
I was under the assumption that both inputs must be true, else relay is off. Actually after re-reading OP I wonder if he wants XOR function? I did not mean to offend, often forum communication creates misinterpretation.
Why do you think you are offending me.:)
Like you I dont not know for sure what the OP wants to do.:rolleyes:
I assumed that the mention of two diodes would start bells ringing in MrDebs head, as a possible solution.
both op amp outputs high
in order for relay to energize
hope I got this right??
In the end, your solution seems to be good one, was not trying to jab you, ya know I luv ya man. :)
another project
it works in simulation
  • battery monitor2.asc
Look at these two modified asc.
When is the battery monitor supposed to switch on/out.?
  • battery monitor2(3).asc
  • temp control.asc
