bryan1
I just acquired a bank of 10 nife nicad batteries as shown in the photo, but 1 of the batteries was tipped over some time ago and the electrolight was spilt and not replaced. The voltage on this battery is 0.97 volts where the other 9 batteries are all around 2.47 volts. also there isn't any details of the amp/hour capacity on the label but here are all the specs off the label
maker:- NIFE made in australia
Type:- SBH38-2
IEC Standard:- RPH38P
Code:- 941
Now for the questions
1) I assume the electrlight is just distilled water, is this correct?
2) I've searched the net for hours to no avail so how can I work out the amp/hour capacity
3) since the electrolight level is nearly empty and the voltage is down to 0.97 volts is the battery stuffed?
I have made up a smart battery charger that will charge nicads aswell as every other type of battery around so once I replace the electrolight I can try to charge the battery.
Cheers Bryan1
Type:- SBH38-2
Code:- 941
Cheers Bryan1
