BarkingMad
Hi there,
I have a quick question for you regarding data offsets on an EPROM chip that I hope you can help with...
I currently have data stored on an EPROM from hex 8000-FFFF, what I would like to do is use 1 8000-1 FFFF for a different set of data. The data sheet says I have an address data latch "When CE is low and ALE is high the address from input buffer is transfer to address decoder by falling edge of ALE". :?
Does that mean that I can run 5v (through a 10k?? resistor) to the ALE pin and it will offset the data to the 1 8000 address range? or would there be a way of altering the signal through A16 which is the Address line.
Many thanks...
Many thanks...
