new PIC CLCDesignerTool with simulator
tumbleweed
Most Helpful Member
For those with an aversion to MPLABX, or who just want a simple, easy to use standalone tool
there is a new, updated version of the old CLCDesignerTool available.
CLCDesignerTool V4 adds features not available in the original version, including:
* support for all PIC18 devices (also supports PIC10/12/16, and a few PIC24 devices)
* support for up to 8 CLC modules
* CLCSELECT register overlay support
* enhanced device ini file format with improved CLC and PPS input and output selections
* BASIC or C output code generation
* output format selectable to support different dialects of BASIC
* improved file operations (Open, Save, Save As)
* ability to load different device configuration files
* new ViewCode window to preview output
* improved output register settings display
There is also a simulator tool available, allowing you to view the interaction of the various CLC module elements.
The files are available at https://www.sfcompiler.co.uk/wiki/pmwiki.php?n=SwordfishUser.CLCDesignerTool
Thanks for that. I think David Barker should be on a retainer with Microchip. His work is superb.
Support for Q10, Q40/41, and Q43... Perfect and so much better than the implementation in MPLABX.
Thank you so much...
Sorry but what about Assembly? Worth even to try?
I removed asm support in favor of different BASIC dialects.
+1.
The hard part is figuring out WHAT to shove into WHICH registers, and in what order (if it matters).
Exactly - I was simply referring to how easy it would be for atferrari to convert from your BASIC or C code to assembler - both basically (no pun intended) pretty well describe what's going on.
