Iam using Holtek Encoder and decoder for RF control of an equipment. I just want to ON and OFF the equipement with a single push button. If pressed once it should turn ON the device and in the next press it should turn OFF....
Here in the decoder , there is a Latch inbuilt. Because of this , if i set a perticular address and a data bit of 0010. it comes in the decoder and turning ON the device and the same data will be there in the latch till the next data comes. When i press the button again, the same address and data will be transmitted , so the device is not turning OFF....
I need to use only one button control for toggling the device... Can any one please suggest an idea to solve this problem plssss....
