Need assistance
rubberlele
Hi! I got this solar battery charger circuit from the internet..
It says that the ciruit can :
-Charges until Vbat = 13,8V (adjustable), then float charges;
-Shuts down load when Vbat < 11V (adjustable), resets at 12,5V;
-Temperature compensation;
-Will work with cheap and readily available components like LM393 comparators and BUZ11 FETs;
-Uses less than 1.3mA (Attempts to use micropower comparators have failed spectacularly so far, see below);
-Burns less than 20mW in FETs when charging at 0,5A. (More expensive FETs with a lower RDSON will yield even better results).
Hope u guys can comment on it before i start building it(whether its okay or not) :)
Very interesting, Everything looks OK, But where are you keeping the charger? Indoors or out?
Also how big is your solar panel?
If you build it let us know how good it is.
Good Luck.
Im using paint :p Haha
Hmmm the charger will be placed outdoor, but i do have a box to place the battery and charger.
Hmmm my solar panel has 17V(max voltage) and around 7A(max current)
I am not much into batteries, but as far as I know too low or too high temperature may degrade or damage batteries.
It's always good to look up the operating temperature range specs of the battery before placing it outdoors.
I think its often placed in the basement or cellar.
