tanveer habib
Hello, I need to make a charger, which gets 220v AC and convert it to 220 DC, also I want to get maximum 10 Amp current on output.
waiting for reply
waiting for reply
Note: This feature currently requires accessing the site using the built-in Safari browser.
Actually a NiMh cell has a nominal voltage of 1.2V, so your basic unit would be a 6S cell-pack.every cell is 7.2 nickle battery.
yes correct each cell is of 7.2 volt and 6.5 amp now my question is can you tell me how much voltage charger is require to charge it fully but not harm it. and as its capacity is 6.5 amp so how much maximum amp can i give it maximum.Actually a NiMh cell has a nominal voltage of 1.2V, so your basic unit would be a 6S cell-pack.
You would need 8 packs to make up your 56V. To charge them safely, each pack's voltage and temperature would need to be monitored.
ICs are available for controlling safe charging of cells in series, but I don't know of any designed to handle 8 packs making up a 56V battery. Other members here may be aware of some.
No. Each cell is 1.2V. The cell-pack (battery) is 7.2V. There;s no such animal as a 6.5A battery. Do you mean 6.5 AmpereHours (Ah)? What is the rated maximum charging current for your cell-pack (this is not the same thing as the Ah capacity)?each cell is of 7.2 volt and 6.5 amp
yes 6.5 AmpereHours and its 1c charging capacityNo. Each cell is 1.2V. The cell-pack (battery) is 7.2V. There;s no such animal as a 6.5A battery. Do you mean 6.5 AmpereHours (Ah)? What is the rated maximum charging current for your cell-pack (this is not the same thing as the Ah capacity)?
