xenoxion said:The thing is, I'm only using one coil, so there's no timing involved. I think I know what the problem is though.... my wire's way too large, I found some normal 22 guage wire and the one I'm using is about 4x larger in diameter. That, combined with my crappy wrapping job, is probably why it doesn't work. I've got to re-wind the coil with some smaller wire, so does anybody have some advice before I do this and possibly screw up again?
Optikon said:xenoxion said:The thing is, I'm only using one coil, so there's no timing involved. I think I know what the problem is though.... my wire's way too large, I found some normal 22 guage wire and the one I'm using is about 4x larger in diameter. That, combined with my crappy wrapping job, is probably why it doesn't work. I've got to re-wind the coil with some smaller wire, so does anybody have some advice before I do this and possibly screw up again?
That might one of the problems but you still will have the tug of war problem even with ONE coil. As long as that one coil remains energized, once the projectile passes through, the coil will try and pull it back (it likely will not be able to but it will slow it down)
xenoxion said:One more question, how can I construct a DC-DC transformer?
xenoxion said:...use some sort of oscillator to produce timed pulses into the transformer, but I don't know why this works, since I thought transformers only work on AC current.
Did you mean 8-10 turns or layers? I used only 5 layers since I saw that on another site somewhere, but I think that's part of my problem. Also, can I just light the tip of my magnet wire on fire to get rid of the enamel?Make the coil the same 30mm in length with 8 to 10 turns of 22 gauge stranded (tinned copper) wire. Coil assembly may be found at my site.
xenoxion said:1. Right now the coil's about 7/8 of an inch long and 5 layers, and the screw barely goes a foot.
2. Is the shower of sparks + bang noise in my previous post normal, and if not how do I fix it?
3. Is there any way I can connect multiple camera units to create a larger power supply?
4. As I said before, I've got 5 330V 120uf caps. If I connect them in parallel, can I also add a 330V 80uf cap to those, or will it screw something up?
