i just needed to know based purly on the wire itself how fast it heats up with a 5 v 1 amp supply and how fast it will cool while submurged in the water?
This thread is so full of crap. SMD resistors to mimic an inkjet printer? An array of 16 thousand motors/solenoids!! That you're going to wind 16 thousand solenoids yourself! The suggestion that you can fire them in sequence 24 times per second. Painting wire to insulate it! This whole thread is just complete garbage.
Whatever you (the OP) are trying to do, you will fail in your current effort.
If you want to succeed then tell us what you are trying to achieve and not what you think the solution might be.
i'm surprised the heat gun doesnt damage things? i guess soldering is just as hot or hotter.
would the resistors operate under fluid?
also which is which i know some of the tiny parts are actually capacitors, how do I tell the difference? are the resistors only the ones with numbers on them?
