Multiplex Design Delay Routines
Suraj143
Active Member
I’m doing a 16 row X 32 column matrix design & the display multiplexing is done in the ISR. At 1mS rate I’m getting into the ISR & update each row on every interrupt. For a frame it will take 1mS X 16 = 16mS.
I need to show moving patterns on the display & for that I need to generate delay routines (In the main code). For the time being I use delays using just delay loop codes.
The problem is, I see a very little flicker thing when the patterns moving. Do I need to generate delays using frames instead of just delay loops?
If you have a 1 mS interrupt then use that to increment a counter and use the counter to time things.
Something like nextEvent=counter+20 and then if(counter>=nextEvent) will execute your code 50 times per second.
Hi Thanks for the idea.
You mean something like this?
ISR_Enter        incf        Counter,F    ;1mS update rate
            retfie
Main_Code        call        Pattern1
            call        Delay_50mS
            call        Pattern1
            call        Delay_80mS
Delay_50mS        clrf        Counter
            movf        Counter,W
            xorlw        .50
            btfss        STATUS,Z
            goto        $-3
            return
Delay_80mS        clrf        Counter
            movf        Counter,W
            xorlw        .80
            btfss        STATUS,Z
            goto        $-3
            return
I was thinking more like this,
IRQ{        counter++;
main{
    while(1){
        if(counter>=timeUp){
            timeUp=counter+20;        wait 20mS
            //do things here 50 times per second
        if(counter>=timeUp2){
            timeUp2=counter+50;
            //do things here 20 times per second
edit, in your case the while(1) would be replaced with a goto main at the end of your code.
Note, if you have count as 32 bit then it will stop working after 49 days due to wrap around.
I got what you mean. You are doing subroutines by comparing the counter variable.So it will work according to predetermined periods.
I need fix delay routines 20mS,30mS,40mS,50mS, 80mS & 100mS. Need to call them whenever I wanted without affecting ISR mux.
Clearing the Counter variable will lead to achieve a maximum 1mS delay error :(
            movf        Counter,W
            xorlw        .50
            btfss        STATUS,Z
            goto        $-3
            return
