Delay Overlap Issue
Suraj143
Active Member
In my LED moving sign I have 8 rows & 40 Columns.
At each interrupt I update 1 row at a time.The animation patterns are in the main loop. The code works.
The only doubt is my subroutine processing times are larger than the interrupt rate (1mS) so it may generate interrupt while I'm processing my subroutine process.
How to overcome this?
Isr_Rate = 1mS
Do_Mux            ---
Do_Row_1        ---
                goto    Mux_Exit
Do_Row_2        ---
Do_Row_3        ---
Do_Row_4        ---
Do_Row_5        ---
Do_Row_6        ---
Do_Row_7        ---
Do_Row_8        ---
                bsf,Flag_Register,End_Frame        ;8mS Time
Load_Disp_Buffer
                copy working regs to display registers
Mux_Exit
Main_Routine
Do_Pat_1        call    Subroutine_1            ;250uS time
                call    Subroutine_2            ;100uS Time
                call    Subroutine_3            ;560uS Time
                call    Subroutine_4            ;380uS Time
                call    Delay_40mS
Delay_40mS        movlw    .5
                movwf    Count        ;8mS X 5 = 40mS
Delay_Loop        bcf        Flag_Register,End_Frame
                btfss    Flag_Register,End_Frame
                goto    $-1
                decfsz    Count,F
                goto    Delay_Loop
                return
Subroutine_1    --
                Return
Subroutine_2    --
                Return
Subroutine_3    --
                Return
Subroutine_4    --
                Return
Speed up your subroutines or slow down the interrupt - try 2mS. This will still give a refresh rate of ~60 fps.
Hi thanks.
I have a small doubt.Even though interrupt happens while in the middle of pattern update routines it wont show on display, because the display registers will update after each frame that is 8mS time...!!!
I assumed the interrupt displayed 1 pattern and returned and hence it would update every 2mS to give a refresh rate of ~60Hz. Note, if your timer interrupt happens before the ISR has finished then your main program will never run.
ISR routine is only for multiplexing part (Just Row update).Patterns are loading in the main routine.There are two register sets.One set is working registers (Pattern loading registers) & the other set is Display registers (used only in ISR routine) now you got it..!!!
So your ISR is just writing 40 columns and then turning on the appropriate row. So, why can't you make your ISR only fire every 2mS to give yourself more time? How are you generating the interrupt?
Exactly now you got it.I need over 100Hz refresh rate.
Like I said earlier I think the Timer overflow interrupt never get crashed.Because in the ISR its is only dealing with display registers.The pattern working registers only will update end of frame that is 8mS time.So I have 8mS time to do my pattern stuff & it will never get crashed.....
