legend killer
Hi everyone,
I had a circuit in which there is a crystal oscillator generating a frequency of 1Mhz.The frequency is then divided by 16
and then by 8 using 74ls93 ripple counters.The output frequuency is approximately 8kHZ.
Uptil now,everything is fine.But now the frequencyof 8kHz is given to monostable multivibrator 74ls122.
The output frequency of this multivibrator is also 8kHz,which is then given to other ic's
The difficulty i am facing is that what is the use of monostable multivibrator,if you can directly have the 8kHz frequency
from the output of 74ls93 ripple counter.The output of 74la122 is given to 74ls165 which is used as parallel to serial
converter.
Thanks in advance for any help
converter.
